there's nothing clever about this circuit - nothing which senses whether the other signal is high before letting this one go high
Somewhere I saw a similar circuit, and this one DID sense the opposing signals, using cross-connections like the ones I added below (in color). I seem to recall this was for the 6509 CPU in one of the Commodore CBM machines. Clearly they wanted to ensure the two output phases couldn't overlap.
But, Richard, I wouldn't worry about the circuit you've got. I suppose you could add the cross connections. But it does seem to work as-is (as Ed said).
Edit: I see George has mentioned much the same solution.
