It is currently Sun Nov 24, 2024 7:46 am
PostPosted: Mon Aug 09, 2021 5:55 pm
On my last project, I just used a simple slider switch for power. Which works well but on my new project, I would like something a little better.
I've been a fan of the rocker switches used on the Commodore 64 and VIC-20. IIRC, those use two voltages.
I've been searching Mouser for a while and think I found one I like:
E101J1V5BE2
https://www.mouser.com/ProductDetail/CK ... cQEA%3D%3D
One glaring observation is that it's really expensive! Well, for me anyway. I suppose I could probably find something cheaper on eBay.
So my questions are, what do you guys recommend? Have you seen something similar but cheaper?
I don't mind paying a little more for a good part. I was just hoping to find something cheaper if I can.
PostPosted: Mon Aug 09, 2021 7:16 pm
I went with https://www.mouser.co.uk/ProductDetail/Mountain-Switch/10TC605?qs=MefMhNUBeRgKkRdFCES7RA%3D%3D for the last build that needed a switch on the board.
For the odd cased board, I have some https://www.mouser.co.uk/ProductDetail/E-Switch/RA1113112R?qs=%2Fha2pyFaduis2gH1eQVji0E2gCBzpFHnXzwFVe1%2Fgmxxsxytiuimzg%3D%3D.
I figured for home builds, a massive number of switching cycles wasn't important. So I went for the less expensive options. The small footprint of the toggle switch and the standard cut-out for the rocker being the deciding factors.
PostPosted: Mon Aug 09, 2021 7:28 pm
I've been using this one on my builds for years:
https://www.mouser.com/datasheet/2/209/ ... 172567.pdf
They work perfectly... however, they came up on the NRND list, so I switched (pun intended) to this one... same PCB layout.
https://www.mouser.com/datasheet/2/140/ ... 346196.pdf
There's basically no difference between them and they have a nice positive feel.
PostPosted: Mon Aug 09, 2021 7:33 pm
Some great recommendations. Thanks!
Users browsing this forum: No registered users and 71 guests
