It is currently Wed Nov 13, 2024 5:50 am
 Post subject: Dual Core Bank Switching
PostPosted: Sun May 09, 2021 12:27 pm
I am working on dual core bank switching. The memory map is intended to approximate Apple, Acorn and W65C265 with equally poor fidelity. A mono core implementation may be of immediate interest to cbmeeks who has been considering variations of Apple memory map.
dual-core-bank0-0-1.pdf [141.06 KiB]
Downloaded 99 times
dual-core-bank0-0-0.odg [8.85 KiB]
Downloaded 60 times
PostPosted: Mon May 10, 2021 5:14 am
What exactly do you mean by dual core bank switching? Sorry not clear about the attached diagram.
2 cores in an FPGA running on the same memory?
2 6502s running on the same memory?
What do you mean by bank? Each core/cpu has it's own view of memory, including the classical view of a bank of 64k memory.
Switching memory access between two CPU is classically done using time sharing - one CPU takes one half of the clock cycle, the second CPU uses the second half (one CPU gets the inverted clock of the other, with bus drivers to separate the address bus. The old 6502 does not even need to separate the data bus in that case, as can be seen in the Commodore dual drive floppies that actually use this.)
André
