Hi guys
I submitted the gerbers for my 65C02GPB2.5 design to JLPCB and they came back with:
"1.There are two board outlines in your file and we have no idea about which one to be used, could you please kindly delete the useless one and re-upload?"
I think they may be referring to the 6 mil traces that I have running around the edge of the board, but I'm not sure. I can say there are not 2 outlines.
Has anyone else come across this issue or might know what else they might be referring to?
Here's a corner of the PCB layout & extra info:
The PCB is a 4 layer one with the copper layers on layer 1 (top, signals), 2 (ground), 15 (power), 16 (bottom, signals)
A. Is the layer 20 (Dimension) and is the actual edge of the PCB. I have checked to ensure that there is only one of these outlines.
B. Is a polygon on layer 15 which fills the power plane
C. Is a polygon on layer 2 which fills the ground plane
D. Is a 6mil trace which goes around the board close to the edge; One on the power plane and one on the ground plane. They both follow the same path, just on different layers.
This is to prevent the copper on those planes from reaching the edge of the PCB and so potentially being exposed to air. I'm not sure if this is actually needed, but I've added them in as a precaution.
