Bill, I like it! The '123 dual timer is a good fit here. No doubt it'll work just fine -- a nice, tidy solution.
But I couldn't leave it alone.
Same as with my own circuits, I felt the urge to tease things around and explore tradeoffs. Instead of measuring time by charging a capacitor we could measure it by counting clock pulses. Depending on circumstances, this revised circuit may have a small advantage. (I'm not suggesting you ought to do it this way. But I thought it was interesting to look at an alternative approach.)
The revised circuit eliminates the resistors and capacitors associated with the RC-based timer chip, but the savings may be offset by the need to add an inverter. Or not, depending on the details of the surrounding glue logic!
The write pulse that's presented to the shift-reg reset input needs to be active-high, not active-low like the read pulse that's applied to the '574 /OE. This is a detail that can perhaps be accommodated for free (it might even
save resources), but in the worst case it will cost you an inverter (as shown).
In the diagram I omitted many of the ground and supply connections, making it somewhat sparse. At the center of the action is the 74HC4015 -- a 16-pin package containing
two serial-to-parallel shift registers. (The 'HC4015 is an update of the old metal-gate CMOS 4015. 4015 and 'HC4015 are both still in production, available in through-hole and SMD.)
Left undisturbed, the reg in the A section will fill up with ones, meaning that Q3 (our output -- the end of the chain) is normally high. When a write occurs the reg's reset input briefly gets pulsed high. The reg is then full of zeros, and it will take four clock before it fills with ones again and Q3 returns high. So, we have a timer that spits out a long-ish low pulse on Q3, mimicking what happens in the first half of the '123 design.
Section B is simply a delay line. When conversion is complete the /INT signal goes low, and that low gets delayed four clocks before emerging at Q3 and being applied to /RD. Low on /RD means /INT will return high... and that high will get delayed by four clocks before reaching /RD. During that time, /RD gets a nice, chunky low pulse, which is what we set out to achieve.
There are some details I didn't bother to figure out; for example, the upper limit re the CPU bus clock. But the ADC will see /RD and /WR pulses that are over three PHI2 clocks in duration, which is favorable. What would provide even longer pulses is if the shift registers were clocked at a rate lower than PHI2. Maybe the clock generated by the ADC0804N would be suitable.
(datasheets here )
74HC(T)4015.pdf [49.25 KiB]
Downloaded 92 times
adc0804-n.pdf [6.7 MiB]
Downloaded 81 times
