It is currently Fri Nov 22, 2024 10:33 pm
PostPosted: Fri Feb 07, 2020 3:19 pm
I'm working on a small 65C02 project that's going to use an LCD screen as a primary display. I already have a 20x4 LCD. I assumed anything larger didn't exist. I searched and found nothing. Well, either my search terms were way off or something as I later found 40x4 LCD's on eBay and Aliexpress. They're a little pricey at around $20 shipped. Not the end of the world but smaller LCD's are much less. So I assume they are pricey because they were never common.
Have you guys seen many LCD's that size in the wild? Do they get larger?
PostPosted: Fri Feb 07, 2020 6:38 pm
I remember using a 40x4 one many (30?) years ago for a project. It was very expensive - more like over £100 at the time! But since then the largest I've used is 20x4.
Mouser has them for about £20 so probably the same in USD if you didn't want to buy via ebay...
Hm. they also have a 40x8 one too, but that's somewhat more pricey and out of stock... It would make for an interesting display for a hand-held though, but I suspect that these days that resolution is achieved much more cheaply using a graphical LCD type at the expense of more software needed to drive it from a 6502 (font, etc.)
Also be aware that some of the generic 16x2 ones are missing the user-definable character font RAM! I found this out recently - all to save a few cents by the clone makers, I guess...
PostPosted: Fri Feb 07, 2020 10:16 pm
I think 40x4 is the largest size that's moderately easy to get hold of. Beyond that, you might as well go for a full graphical LCD.
PostPosted: Fri Feb 07, 2020 11:10 pm
40x4's are still easy to get (last I checked). There used to be 80-column ones back when typewriters were going electronic and everyone didn't have computers with printers and word processors yet. I think that segment of time was pretty short.
PostPosted: Sat Feb 08, 2020 3:55 am
I got one recently for a project, the PCB hasn’t arrived so I haven’t got it going yet, but the data sheet says that it has two controllers, complete with their own chip selects, each controller is responsible half of the display.
Users browsing this forum: Google [Bot] and 33 guests
