I've changed E6 now, I bought two old stock SN74100Ns from an Ebay trader. The odd thing is, unless both of the chips I bought are faulty (they're apparently unused) E6 is no longer doing much of anything, and it seems that this is because C2 pin 8 is now stuck high at 4.3V. It goes without saying that there's still no vertical sync.
C2 - pin 8 - 4.3V (before I changed E6 it was 15.625KHz, 64µs, 1.4Vrms)
C2 - pin 9 - 15.625KHz @ 5v
C2 - pin 10 - high
So I went back from C2 pin 10 to B1 pin 8, which of course is 4.3V high. B1 is fed by A1, which I'd previously measured at:
old measurements wrote:
1 - 16.556KHz 60µs at 3.48V - this appears to be a clock input from D5 (74LS107)
2 - 0.16V
3 - 5.11V
4 - 0V - pin not connected
5 - 5.11V - power rail
6 - 0V - pin not connected
7 - 0V - pin not connected
8 - 3.906KHz 256µs at 3V - output to A2 6540 and B1 74LS20 and E8 74LS04
9 - 7.812KHz 128µs at 2.92V - output to A2 6540 B1 74LS20
10 - 0V - ground
11 - 1.953KHz 512µs at 3V - output to A2 6540, B1 74LS20 and E8 74LS04
12 - 0.08V
13 - 0V - pin not connected
14 - 4.05V
And now, A1 is showing no outputs on 8, 9, 11 and 12:
1 - 15.625KHz
2 - 15.625KHz (at about 1v)
3 - 5.1V
4 - 0V
5 - 5V
6 - 0V
7 - 0V
8 - 0V
9 - 0V
10 - 0V
11 - 0V
12 - 0V
13 - 0V
14 - 4.5V
I'm at a loss to explain this behaviour. It seems unlikely that A1 has failed suddenly.
