The second 4 Bit latch in E6 (74100): //inputs at the left, outputs at the right:
pin 11 (0V,low) > pin 8 (0V,low)
pin 10 (0.2V,low) > pin 9 (0V,low)
pin 15 (3.85V,high) > pin 18 (3.85V,high)
pin 16 (0V,low) > pin 17 (0V,high)
The logic levels at the inputs an outputs of that latch per Bit does match,
so we could assume for now that the 4 Bit latch is working.
But there are no signals, means the counter D7 (74177) attached to the latch does not count.
I'm not sure if the counter D6 (74177) does count as it should, but at least there are signals at some of the outputs...
So check the control inputs of D7:
Pin 1 (/LOAD), pin 13 (/CLR). Those pins are shared with the D6 counter.
Pin 6, pin 8. Those pins are the clock inputs.
Thankyou for helping here, it's great to learn how this all works. As a child I just stared at it and thought it was magic...
It isn't sorcery, but trying to figure out how some of the old TTL circuitry out there works might be a bit difficult sometimes.
Basically, D6 and D7 generate the address for the display RAM.
The amount of characters per line to be displayed isn't a multiple of 2 (not 32 or 64), the latch E6 compensates for this.
It appears that the output of the address counter also is used for identifying
in which raster line the the VSYNC has to be generated (seems to be the logic gates feeding D8 pin 4),
and in which raster line displaying characters has to end (seems to be the logic gates feeding D8 pin 5).
