cbmeeks wrote:
Oh yeah. I still have my 10 PCB's I made earlier. I keep one on display as a reminder. I use another as a bookmark. LOL.
Pedestal for coffee cups.
cbmeeks wrote:
However, I plan on using two of these boards in the immediate future. One as a bench PC and the other in a case I want to put on display. So for them I want some good connectors. Do you have any recommendations?
MPE Garry 115-2-020-0-MTF-XS0.
Fischer Elektronik
BL6 025 series.
Fischer Elektronik has some nice nice stuff: heat sinks, casings, etc., but industry grade parts ain't cheap.
BTW: when a PCB trace goes to a connector pin, in my PCB layouts I tend to make the last segment of the trace 32 mil or such,
just to make sure the traces to the connector pins don't get hairline cracks after a lot of connector plugging/unplugging cycles.
Sometimes I also did this with EPROM sockets.
cbmeeks wrote:
I figure when I design a real PCB for expansion slots, I will make it more "L shape" to accommodate large caps.
Murata
GRM31CR60J227ME11L, ceramic 1206, 220uF 6.3V 2.10€ ?
Hmm... from the
ST datasheet, 78xx regulators with >6V output can be damaged when they have a lot of capacitance at the output
while the input is switched to GND, and suggest to add a diode reversed between input and output as a protection.
If you are paranoid that your voltage regulator might be getting damaged during power_off,
you could add something like a 1N4007 to your voltage regulator.
The MIC29300-5.0WT I had mentioned above in the thread costs ca. 3€, has short circuit current protection,
doesn't mind a lot of capacitance at the output, can take -20V input voltage...
and because it's a low drop regulator, in theory it can generate 5V from a 6V input voltage at 3A.
7805 would need more than 8V at the input for generating 5V.
Of course the interesting question is how the output voltage of your "wall wart" goes down when current increases,
and how much AC ripple the "wall wart" has at the output while sourcing the full current.
Another idea would be buying a switchmode power supply like the
Meanwell RS-15-5 for ca. 8€.
cbmeeks wrote:
[SB560 diode preventing negative supply voltage]
Yeah, that's a good idea as well. I may add that on my next revision. I will certainly add it on my next design.
SMD version of the SB560 would be
SK56C.
Also, it would be good to add a
TVS diode (transient voltage supressor) against electrostatic discharge between +5V and GND.
BTW: Just taking a look at real.video gives me a headache.
