Alarm Siren wrote:
1. There appears to be a Casette PCB edge connector on the inside of the Datasette. I don't understand why you'd want to connect a Datasette to a Datasette, especially as it would not normally be accessible?
I'm guessing, but maybe the connector is only used for setup/testing (in the factory).
2. There's some kind of wire sticking out of the lead, an wire braid with no insulation with a screw loop on the end.
Braid is usually a shield. Maybe the screw loop is supposed to go under one of the C64 screws which inserts into the (grounded) chassis.
A photo might be helpful.
J
![Smile :)](./images/smilies/icon_smile.gif)
