Huh. I don't notice anything conspicuously wrong here. BTW on this forum you're allowed to make attachments with your posts -- which is more convenient (and more permanent) than using a third-party site such as imgur. Also BTW, some folks find that Eagle schematics are more legible without the use of color. I've taken the liberty of making a monochrome rendition:
A few faintly bothersome points:
The schematic includes the signal names CLK and CLKIN. CLK drives two inputs on IC5 (the NAND), but I wasn't able to find the
origin of this signal -- did I miss it? The obvious guess is that it comes from pin 39 of the CPU. Is it possible that you and Eagle have had a misunderstanding?
The I/O circuitry is not included on this diagram, and I presume it's located on a separate card. Which leads to the question, was the I/O card disconnected when you performed your tests? If the tests involved the I/O card then it'll be best if you supply that schematic too.
Should we ignore the Rockwell part # R65C03P3 and assume you're using a WDC 'C02? The logic that generates RAM_CSL could be simplified, but what you've got there doesn't seem
wrong.
I kind of like how you've used the 74HC85.
And you're right, it's no speed demon; but at low clock rates it should be fine. In future you might wanna consider an 'AC85 instead.
