It is currently Fri Nov 22, 2024 8:58 pm
PostPosted: Fri May 27, 2016 1:41 pm
None of my recent (2009+) computers have a true 9-pin serial port. Which is a shame.
I use a USB to serial adapter for programming micro-controllers and I'm pretty sure it has the FTDI chip inside.
On my SBC I'm building, I want to include a 65C51 but I've seen designs where people use another MAX-232 chip as well.
Am I correct in thinking that I won't really need one (MAX-232) if I only use the USB/serial adapter I have?
Can the ACIA talk directly to that adapter I have? I'm in the process of learning more about that chip.
BTW, this is the adapter I have:
https://www.parallax.com/product/32201
PostPosted: Fri May 27, 2016 1:53 pm
That looks fine to me: the crucial thing is that it supports TTL levels (or even 3V3 levels) and doesn't need a line driver. It's not suitable for long distance but will probably be OK up to a metre.
The other day I connected up a 3V3 serial from a raspberry pi to a USB serial adapter, using paper clips. It was fine at 115200 baud.
PostPosted: Fri May 27, 2016 2:22 pm
Hmmm. It could be possible that my main computer could sit on the other side of the room from my SBC. Maybe 10 feet.
What would you recommend then?
That. Is. Awesome.
PostPosted: Fri May 27, 2016 2:31 pm
You'll need more than paper clips! You'll certainly be safe with a proper driver and cables. To see if you can get away with less, you'll have to experiment I think.
PostPosted: Fri May 27, 2016 2:38 pm
Pardon my ignorance, but is the MAX-232 the "driver" in this example? Still not sure what that chip is really used for.
Thanks.
Oh, I do like the idea of a string of paperclips going across the floor. That's the "manly" way to do it. LOL Oh wait...barbed wire. That's how I should do it.
PostPosted: Fri May 27, 2016 2:42 pm
Yes, full RS232 uses higher voltages, and the MAX chip does the conversion.
"The drivers provide TIA-232 voltage level outputs (about ±7.5 volts) from a single 5-volt supply by on-chip charge pumps and external capacitors. This makes it useful for implementing TIA-232 in devices that otherwise do not need any other voltages. The receivers reduce TIA-232 inputs, which may be as high as ±25 volts, to standard 5-volt TTL levels. These receivers have a typical threshold of 1.3 volts and a typical hysteresis of 0.5 volts."
- https://en.m.wikipedia.org/wiki/MAX232
For extra distance/robustness, you can use differential signalling.
PostPosted: Fri May 27, 2016 2:45 pm
You could also use a long USB cable to make up some of the distance...
"USB Cable Length Limitations: The USB specification limits the length of a cable between full speed (or high speed) devices to 5 meters (16 feet 5 inches) and for low speed devices the limit is 3 meters (9 feet 10 inches)."
PostPosted: Fri May 27, 2016 2:57 pm
Yeah, I think I could make the USB cable work. Any serial device I put on my retro SBC will normally never be more than a few feet away. I could probably even re-arrange some stuff on my desks to shorten that distance.
So, knowing that, do you think I can get away with using just a 65C51 and nothing else?
Thanks
PostPosted: Fri May 27, 2016 3:17 pm
I would think so - I'd certainly give it a try.
PostPosted: Fri May 27, 2016 7:30 pm
The MAX-232 (also -238 and -248) is a transceiver that does several things for you:
  1. Level conversion. UART inputs and outputs operate at (mostly) TTL voltage levels, and are inverted logic-wise relative to TIA-232. TIA-232 swings (roughly) between plus and minus 12 volts relative to ground. The MAX-232 and brethren handle the voltage disparity and also invert the logic.
  2. Line driving. The output of the MAX-232 is a low impedance current source that can drive relatively long cables (I've tested them out to several hundred feet). The UART doesn't have that kind of drive, so the signal would rapidly fade with distance.
  3. Protection. The UART would probably be fatally damaged if exposed to a voltage spike more than about 25 percent above its nominal Vcc rating. The MAX-232 can tolerate as much as ±30 volts on its inputs and up to ±15 volts on its outputs.
Automobile battery cables would work. I-squared-R losses would be very low. :D
PostPosted: Fri May 27, 2016 7:42 pm
I see BDD did a good job of answering while I was writing, but I'll post anyway.
Thanks.
From my RS-232 primer:
      The transmitting standard goes like this: Logic 0 is +5V to +15V. Logic 1 is -5V to -15V. -5V to +5V is the transition area. Transmitters can handle indefinite shorts to each other or to ground without damage. Again, the voltages seem backwards; but it's because the line drivers and receivers invert the signal.
      Powering the line drivers from ±12V used to be pretty standard, but line drivers like the MC145407 and the well known MAX232 and its many relatives use internal switched-capacitor voltage converters and multipliers to get (almost) ±10V from a single 5V supply. Still, if you have ±12 (or something in that neighborhood) on the board to power the line drivers, ones like the 1488 or MC145406 take less board space, because they don't need external capacitors and the extra pins to connect to them.
      For low-power hand-held applications where battery power is saved at all costs, it is also possible to power the line drivers with power taken from the receivers' input signals. A unit designed like this would have to be connected to another computer that will supply the power. Obviously it won't work if it is connected to another one of the same which also supplies no power, especially if you have a hand-held terminal with no power source of its own.
      The receiving standard goes like this: Logic 0 is +3V to +25V. Logic 1 is -3V to -25V. -3V to +3V is transition area. Specified impedance for one receiver load is 3KΩ to 7KΩ. One output can usually drive quite a few inputs (and LEDs for troubleshooting).
      To reduce problems with noise and interference, the receiver usually has some hysteresis to keep its output steady at the last valid logic level while the input is crossing that transition area, and then outputs a fast edge to the UART when it does go to the other logic level.
I don't know how fast you could go with it (the long cable might require slowing down to get valid data through), but it looks like the logic levels will be ok for the device you linked to. BDD brought up the matter of possible damage from static discharge. You'll have to be careful, or add some other kind of protection. You could use something like 74LS__ parts for that, but then you might as well just use the normal line drivers and receivers.
Users browsing this forum: Yuri and 32 guests
