It is currently Fri Nov 01, 2024 9:36 am
PostPosted: Thu Jan 28, 2016 4:08 pm
hi
I am designing a 6809 board with Eagle/CAD, I can't find a valid device XC95144 & XC95108 (they are 5V CPLD), I have found an old library called XILINX.lib but my Eagle v7.2 says that it's too old. Does anyone happen to have a library with these XC95xxx device on hand ?
thank you in advance
PostPosted: Thu Jan 28, 2016 7:06 pm
I'm not familiar with Eagle, but you should be able to easily and quickly make you own custom components. I've done it hundreds of times for my work, in my CAD, for unusual parts, and even for making common parts like resistors and capacitors so I can get higher board density than I could with the PCB components that were supplied with the CAD.
PostPosted: Mon Feb 01, 2016 1:50 pm
yes, but it takes effort and skills, and so I ask
PostPosted: Fri Feb 05, 2016 7:04 pm
I have the footprint, but I still use 5.11, and so I am afraid my lbr will have the same issue. Any way you can bring up a EAGLE 6 and convert them to the new XML format?
Or, maybe the XILINX lbr has been updated at the EAGLE's web site. There is a download page for lbrs there.
Jim
