Klaus2m5 wrote:
You probably get closer to VIH = MAX and the 3.7V should fade... If neither side starts to emit smoke it is OK.
So far no magic smoke - but probably it will shorten lifespan...
Klaus2m5 wrote:
However, it would work better, if you would sacrifice a chicken before applying power...
Although I have raised and eaten some chickens (and all necessary stepsin between), I better not venture into voodoo
cbscpe wrote:
Do you have any small MOSFETs like BSS138, AO3400, 2N7000 and some 10k resistors? Then you could build one of those simple bidirectional level signal converters (see "level shifter mosfet" in google), that should do the job for your SPI.
No MOSFETs here (or-- maybe some really BIG ones that fell out of a scavenged switching power supply) - but I don't need bidircetiona signals. CS, CLK, MOSI are all from master to slave, i.e. 5V --> 3.3V, and MISO is 3.3V --> 5V.
I probably change the power supply to Zener diode+resistor, and the signal shift to dividing voltage by using 1k+2k Ohm resistors.
