It is currently Sat Nov 23, 2024 1:12 am
PostPosted: Sat Jun 06, 2015 7:28 am
As I'm using an old NMOS 6509 I'm thinking about different memory layouts:
    Simply switching the whole 64kb with the MMU registers 00/01 - easy to implement, but the botched design with the registers 00/01 appearing everywhere making the address space non-continuous. Dr. Jeffyl, you said something about "the flawed but fixable 6509" (http://forum.6502.org/viewtopic.php?f=10&t=2997&hilit=6509#p33930) - are there really ways to fix that issue? Or was that a fix in a FPGA redesign?
    Using 00/01 to switch 16kb/32kb memory banks, e.g. CPU sees C000-FFFF part of a 256kb ROM, P0-3 select which 16kb of the ROM are accessible. As the 6509 doesn't have continuous memory space anyway, I could keep ZP,Stack and I/O in all memory configurations.
    Taking a completely different approach, which doesn't use 6509s features (but they surely will be re-used in some other way): Instead of banking in a larger window of 16-32kb, focus on the 6502 architecture and use banks of two pages (to allow for abs,X/abs,Y). That would mean CPU can do pointer arithmetic at 8-bit boundaries. Each window would require a set of adders so bit 9 can be calculated in. At my 2MHz speed there would be enough time (300ns TACC, 100ns RAM, that leaves 200ns - almost propagation delay of almost 10 times nibble adders), at higher speeds that would be difficult. And, of course, this would require quite some board space.
PostPosted: Sat Jun 06, 2015 5:08 pm
Hobbit1972 wrote:
"the flawed but fixable 6509" (viewtopic.php?f=10&t=2997&hilit=6509#p33930) - are there really ways to fix that issue? Or was that a fix in a FPGA redesign?
I meant a redesign -- something that would allow us both to have the registers at 00/01 (because they're necessary for mapping control)... and also not have the registers at 00/01 (because they fragment the 1 MB space)! Here's how. Indirect-Y mode is mandatory when accessing extended memory via the registers, but a person would never need to use Indirect-Y mode to access the registers themselves. That means the problem would be solved if the select logic for accessing the registers themselves would look for address 0000/0001 and require that Indirect-Y mode not be in effect. That'd be easy to arrange in an FPGA design but it's not something you could retrofit to an existing 6509.
( Maybe existing 6509s do feature such logic. After all, it would've been easy for MOS to do it that way -- a minor change with major benefits! But the datasheet is vague, and I don't have a 6509 to test. Therefore I posed the question in this post, which is part of the thread MOS 6509 look-alikes. )
Clever idea -- I like it!
Another clever idea. I think I understand, but, to be sure, let me explain it back to you.
In the small map (64K) you have a page set aside -- let's say it's page $20 ($2000-$20FF). Your custom hardware causes page $20 to map to any desired page in the big map (1 megabyte?). For example, page $20 might map to page $113 ($11300-$113FF). But what do we do if indexing causes the CPU to output an address in page $21 instead? Your plan is to also have page $21 set aside. Of course it must map to page $114 for indexing to work -- and the adder you mentioned would compute $113 + 1 = $114.
The adder idea is workable, but the delay is a potential problem. There are alternatives. Since you already need some sort of register to hold the extended page address ($113), you could easily have another register to hold the $114. Software would pre-increment the value at the time both registers were loaded. If you used 74_670 IC's then the extra register would not require a lot of additional wiring. (For more on the '670, see the topic here.)
PostPosted: Sat Jun 06, 2015 5:32 pm
I meant a redesign
I tested yesterday evening - sadly lda/sta ($00),y accesses the CPUs registers not memory.
TY :)
I wonder if there would be an easy way to switch between windows of 32kbROM+16kbRAM and 16kbROM+32kbRAM.
Yes, you got it. And brought a major improvement to it.
PostPosted: Sat Jun 06, 2015 7:14 pm
I've found that, with enough headstrong obstinacy, almost anything is possible! :D
Is this a typo, Ralf? Based on my reading of the 6509 datasheet, you'd never code a lda/sta ($00),y. The operand could be from $02 to $FE, but $00 isn't useful. Here's a code example.
;Objective: fetch the value at $12345 (20-bit address)
ZPg_Ptr        equ $34 ;or whatever -- just an ordinary 65xx indirect pointer
6509_Ind_Reg   equ $01 ;special 6509 register at $01
lda #$45       ;bits  7-0 of "$12345"
sta ZPg_Ptr
lda #$23       ;bits 15-8 of "$12345"
sta ZPg_Ptr+1
lda #$01       ;bits 19-16 of "$12345"
sta 6509_Ind_Reg
ldy #0           ;no indexing in this simple example
lda (ZPg_Ptr),Y  ;use of lda (ind),Y triggers the 6509_Ind_Reg. Acc is left = contents of $12345
The suspected flaw is that this won't work if (for example) the value $12345 is replaced with any value ending in 0000 or 0001. Instead of accessing memory, the 6509 will access the special registers.
ETA: we need to access the special registers, but not with (ind),Y mode. In the code example I simply sta zero-page to update 6509_Ind_Reg.
PostPosted: Sat Jun 06, 2015 7:47 pm
Oh, yea, typo.... I meant ($02) and 02/03 containing 0000. :mrgreen:
sta ZPg_Ptr
sta ZPg_Ptr+1
sta 6509_Ind_Reg
Yes, this flaw is not only suspected, but tested (see 6509-thread and my 6509 produced the same botched result). If ZPg_Ptr contains 0000 or 0001 - then access goes to register, memory (in writes) will contain what remains on the data bus (=in my case ZPg_Ptr address, $34 here).
PostPosted: Sat Jun 06, 2015 10:15 pm
A slight side track: I thoughthe 6809 as made by Motorla, not MOS? I dont't know huge amounts about it so I might be wrong.
PostPosted: Sat Jun 06, 2015 10:35 pm
6809, yes, made by Mot. Not the 6509 though.
PostPosted: Sat Jun 06, 2015 10:46 pm
Ahh ok. Forum posting late at night leads to silly mistakes :oops:.
Looking at the wiki entry it does seem to get slated for it's bank switching mechanism.
Why not use a 65816? Or is it a nostalgia thing?
PostPosted: Sun Jun 07, 2015 10:12 am
Explanation of the nostalgia thing see here: http://forum.6502.org/viewtopic.php?f=12&t=3312 :)
