It is currently Sat Sep 21, 2024 7:36 am
PostPosted: Mon May 25, 2015 7:51 pm
Might be of interest:
What could be more fun than than to build a nice 65c816 computer. The core system has 1M SRAM, 256K EEPROM, Serial, VGA, RTC and SD card Interface. Open Architecture allows memory expansion, Commodore SID board or other "cool" feature creep.
https://hackaday.io/project/2993-shemachine
I used poor mans wire wrap, Wire wrap sockets are so expensive anymore so I use Single inline headers with the wires pushed flat to the plastic holder. I stuff these through the board and solder them to each pin on the socket.
This is more akin to verowire than wirewrap, but I see the benefit in a cheap and convenient construction technique. (Wirewrap is redoable, which is handy.)
PostPosted: Mon May 25, 2015 9:03 pm
It looks like it's kind of a hybrid. He is using wire wrap for point to point from the pin headers, but soldering sockets and jumpers to the pin headers. I saw someone else do this on YouTube for similar reasons, wire wrap sockets are too expensive, and making PCB's for one offs is a hassle.
PostPosted: Mon May 25, 2015 9:38 pm
Ah, thanks, that makes more sense! (To get proper welding at the contact points, you need sharp square pins to wrap the wire. So choose your parts with care.)
