The FPGA does generate the clock, and it is only a single 40MHz clock.
The 6502 sees this as divided by 6 for 6.66 Mhz.
When I replace the 65C02 with an AVR doing IO emulation, the noise is gone.
I just found a tray of ADV7123s in my stash, so I am going to try soldering one up.
The digital DAC will be more resistant to this, as it will gate the data.
Here are some photos showing the noise, which manifests as slight changes in brightness.
There are subtle, so I added contrast in Photoshop so they were more visible.
Note that the vertical bands are called "moire lines", and happen when trying to photograph a screen.
These lines are not actually present in real life.
From a distance, the noise isn't all that noticeable.Here is a closer image of the noise enhanced a bit with contrast.
The noise corresponds to about the time the 6502 is accessing SRAM.
The slight changes happen when the 6502 talks to the SRAM.When I remove the 65C02 and put my AVR emulator in, the noise is completely gone.
The AVR does an IO exact clone of the 6502, so timing is precisely the same.
An AVR emulating a 6502 does not produce any noise at all.I am thinking that the real DAC will completely eliminate this issue and offer a much better image as well.
Normally, this would be "good enough", but I really like this project as a platform for making 6502 games and demos!
I just finished the sound, and it is just like the Amiga. 4 channels with precise frequency and volume control.
The unit also acts as a USB mass storage device to the PC, so I can code in my 6502 assembler and see code run in a few seconds.
Anyhow, I will play around and see what develops.
Seeing the AVR pretend to be a 6502 with a clean signal makes me think that the 6502 is just more power hungry.
Thanks,
Brad
