Hi all,
Following up on
mkl0815's excellent thread, I created an AT28C16 EEPROM programmer from an Arduino Uno. I've attached a photo and a schematic. I am using this to create different character generator ROMs for an Apple II+. I'm also including my Arduino code in case this is helpful to anyone else.
Chris
// Arduino Uno Programmer for AT28 EEPROM
// Chris Torrence, 2015
// ideas from: http://forum.6502.org/viewtopic.php?f=4&t=2491
#define SER_Pin A4 // 75HC595 pin 14, serial input
#define STCP_Pin A2 // 75HC595 pin 12, STCP storage register clock
#define SHCP_Pin A1 // 75HC595 pin 11, SHCP shift register clock
#define AT28_CE_Pin 10 // AT28C64 WE, write enable
#define AT28_WE_Pin 11 // AT28 WE, write enable
#define AT28_OE_Pin 12 // AT28 OE, output enable
#define numOfRegisterPins 11 // 2^11 = 2048 address locations
#define ADDRESS_MAX (1 << numOfRegisterPins)
// Fast way of setting/reading/writing pins on the Arduino
// http://masteringarduino.blogspot.com/2013_10_01_archive.html
#define portOfPin(P)\
(((P)>=0&&(P)<8)?&PORTD:(((P)>7&&(P)<14)?&PORTB:&PORTC))
#define pinOfPin(P)\
(((P)>=0&&(P)<8)?&PIND:(((P)>7&&(P)<14)?&PINB:&PINC))
#define pinIndex(P) ((uint8_t)(P>13?P-14:P&7))
#define pinMask(P) ((uint8_t)(1<<pinIndex(P)))
#define digitalLow(P) *(portOfPin(P))&=~pinMask(P)
#define digitalHigh(P) *(portOfPin(P))|=pinMask(P)
#define isHigh(P) ((*(pinOfPin(P))& pinMask(P))>0)
#define isLow(P) ((*(pinOfPin(P))& pinMask(P))==0)
// Data to be written to the AT28.
// Use PROGMEM to put into Arduino flash memory
prog_uchar values[2048] PROGMEM = {
28, 34, 42, 42, 44, 32, 30, 0, 8, 20, 34, 34, 62, 34, 34, 0, 60, 34, 34, 60, 34, 34, 60, 0, 28, 34, 32, 32, 32, 34, 28, 0,
60, 34, 34, 34, 34, 34, 60, 0, 62, 32, 32, 60, 32, 32, 62, 0, 62, 32, 32, 60, 32, 32, 32, 0, 30, 32, 32, 38, 34, 34, 30, 0,
34, 34, 34, 62, 34, 34, 34, 0, 28, 8, 8, 8, 8, 8, 28, 0, 2, 2, 2, 2, 2, 34, 28, 0, 34, 36, 40, 48, 40, 36, 34, 0,
32, 32, 32, 32, 32, 32, 62, 0, 34, 54, 42, 42, 34, 34, 34, 0, 34, 34, 50, 42, 38, 34, 34, 0, 28, 34, 34, 34, 34, 34, 28, 0,
60, 34, 34, 60, 32, 32, 32, 0, 28, 34, 34, 34, 42, 36, 26, 0, 60, 34, 34, 60, 40, 36, 34, 0, 28, 34, 32, 28, 2, 34, 28, 0,
62, 8, 8, 8, 8, 8, 8, 0, 34, 34, 34, 34, 34, 34, 28, 0, 34, 34, 34, 34, 34, 20, 8, 0, 34, 34, 34, 42, 42, 54, 34, 0,
34, 34, 20, 8, 20, 34, 34, 0, 34, 34, 20, 8, 8, 8, 8, 0, 62, 2, 4, 8, 16, 32, 62, 0, 62, 48, 48, 48, 48, 48, 62, 0,
0, 32, 16, 8, 4, 2, 0, 0, 62, 6, 6, 6, 6, 6, 62, 0, 8, 20, 34, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 62, 0,
0, 0, 0, 0, 0, 0, 0, 0, 8, 8, 8, 8, 8, 0, 8, 0, 20, 20, 20, 0, 0, 0, 0, 0, 20, 20, 62, 20, 62, 20, 20, 0,
8, 30, 40, 28, 10, 60, 8, 0, 50, 50, 4, 8, 16, 38, 38, 0, 24, 36, 40, 16, 42, 36, 26, 0, 8, 8, 8, 0, 0, 0, 0, 0,
8, 16, 32, 32, 32, 16, 8, 0, 8, 4, 2, 2, 2, 4, 8, 0, 8, 42, 28, 8, 28, 42, 8, 0, 0, 8, 8, 62, 8, 8, 0, 0,
0, 0, 0, 0, 0, 24, 8, 16, 0, 0, 0, 28, 0, 0, 0, 0, 0, 0, 0, 0, 0, 24, 24, 0, 0, 2, 4, 8, 16, 32, 0, 0,
28, 34, 38, 42, 50, 34, 28, 0, 8, 24, 8, 8, 8, 8, 28, 0, 28, 34, 2, 12, 16, 32, 62, 0, 62, 2, 4, 12, 2, 34, 28, 0,
4, 12, 20, 36, 62, 4, 4, 0, 62, 32, 60, 2, 2, 34, 28, 0, 14, 16, 32, 60, 34, 34, 28, 0, 62, 2, 4, 8, 16, 16, 16, 0,
28, 34, 34, 28, 34, 34, 28, 0, 28, 34, 34, 30, 2, 4, 56, 0, 0, 0, 24, 24, 0, 24, 24, 0, 0, 0, 24, 24, 0, 24, 8, 16,
4, 8, 16, 32, 16, 8, 4, 0, 0, 0, 60, 0, 60, 0, 0, 0, 16, 8, 4, 2, 4, 8, 16, 0, 28, 34, 4, 8, 8, 0, 8, 0,
156,162,170,170,172,160,158,128,136,148,162,162,190,162,162,128,188,162,162,188,162,162,188,128,156,162,160,160,160,162,156,128,
188,162,162,162,162,162,188,128,190,160,160,188,160,160,190,128,190,160,160,188,160,160,160,128,158,160,160,166,162,162,158,128,
162,162,162,190,162,162,162,128,156,136,136,136,136,136,156,128,130,130,130,130,130,162,156,128,162,164,168,176,168,164,162,128,
160,160,160,160,160,160,190,128,162,182,170,170,162,162,162,128,162,162,178,170,166,162,162,128,156,162,162,162,162,162,156,128,
188,162,162,188,160,160,160,128,156,162,162,162,170,164,154,128,188,162,162,188,168,164,162,128,156,162,160,156,130,162,156,128,
190,136,136,136,136,136,136,128,162,162,162,162,162,162,156,128,162,162,162,162,162,148,136,128,162,162,162,170,170,182,162,128,
162,162,148,136,148,162,162,128,162,162,148,136,136,136,136,128,190,130,132,136,144,160,190,128,190,176,176,176,176,176,190,128,
128,160,144,136,132,130,128,128,190,134,134,134,134,134,190,128,136,148,162,128,128,128,128,128,128,128,128,128,128,128,190,128,
128,128,128,128,128,128,128,128,136,136,136,136,136,128,136,128,148,148,148,128,128,128,128,128,148,148,190,148,190,148,148,128,
136,158,168,156,138,188,136,128,178,178,132,136,144,166,166,128,152,164,168,144,170,164,154,128,136,136,136,128,128,128,128,128,
136,144,160,160,160,144,136,128,136,132,130,130,130,132,136,128,136,170,156,136,156,170,136,128,128,136,136,190,136,136,128,128,
128,128,128,128,128,152,136,144,128,128,128,156,128,128,128,128,128,128,128,128,128,152,152,128,128,130,132,136,144,160,128,128,
156,162,166,170,178,162,156,128,136,152,136,136,136,136,156,128,156,162,130,140,144,160,190,128,190,130,132,140,130,162,156,128,
132,140,148,164,190,132,132,128,190,160,188,130,130,162,156,128,142,144,160,188,162,162,156,128,190,130,132,136,144,144,144,128,
156,162,162,156,162,162,156,128,156,162,162,158,130,132,184,128,128,128,152,152,128,152,152,128,128,128,152,152,128,152,136,144,
132,136,144,160,144,136,132,128,128,128,188,128,188,128,128,128,144,136,132,130,132,136,144,128,156,162,132,136,136,128,136,128,
32, 16, 8, 0, 0, 0, 0, 0, 0, 0, 28, 2, 30, 34, 30, 0, 32, 32, 44, 50, 34, 50, 44, 0, 0, 0, 30, 32, 32, 32, 30, 0,
2, 2, 26, 38, 34, 38, 26, 0, 0, 0, 28, 34, 62, 32, 28, 0, 12, 18, 16, 56, 16, 16, 16, 0, 0, 2, 28, 34, 34, 30, 2, 28,
32, 32, 44, 50, 34, 34, 34, 0, 8, 0, 24, 8, 8, 8, 28, 0, 4, 0, 12, 4, 4, 4, 36, 24, 32, 32, 34, 36, 56, 36, 34, 0,
24, 8, 8, 8, 8, 8, 28, 0, 0, 0, 52, 42, 42, 42, 42, 0, 0, 0, 44, 50, 34, 34, 34, 0, 0, 0, 28, 34, 34, 34, 28, 0,
0, 0, 44, 50, 50, 44, 32, 32, 0, 0, 26, 38, 38, 26, 2, 2, 0, 0, 44, 48, 32, 32, 32, 0, 0, 0, 30, 32, 28, 2, 60, 0,
16, 16, 56, 16, 16, 18, 12, 0, 0, 0, 34, 34, 34, 38, 26, 0, 0, 0, 34, 34, 34, 20, 8, 0, 0, 0, 34, 42, 42, 42, 20, 0,
0, 0, 34, 20, 8, 20, 34, 0, 0, 0, 34, 34, 38, 26, 2, 28, 0, 0, 62, 4, 8, 16, 62, 0, 6, 8, 8, 48, 8, 8, 6, 0,
8, 8, 8, 0, 8, 8, 8, 0, 48, 8, 8, 6, 8, 8, 48, 0, 0, 0, 16, 42, 4, 0, 0, 0, 42, 20, 42, 20, 42, 20, 42, 0};
// Procedure to set and display registers:
// STCP low
// For each address bit (high to low): SHCP low, write bit, SHCP high
// STCP high to transfer to the storage register (and the output)
void writeShiftRegister(long val)
digitalWrite(STCP_Pin, LOW);
// From highest bit to lowest bit
for(int i = 15; i >= 0; i--)
digitalWrite(SHCP_Pin, LOW);
digitalWrite(SER_Pin, (val >> i) & 1); // Write the next highest bit
digitalWrite(SHCP_Pin, HIGH); // Left shift the register 1 bit
digitalWrite(STCP_Pin, HIGH);
// Light up the LEDs using each valid address
void testShiftRegister()
// Just light up the LEDs in order.
writeShiftRegister(0);
delay(200);
for (int i=0; i < numOfRegisterPins; i++)
writeShiftRegister(1 << i);
delay(100);
// Light them all up, then turn them off.
writeShiftRegister(2047);
delay(100);
void printValue(int address, byte value)
if (address % 32 == 0)
Serial.println("");
Serial.print("$");
if (address < 256) Serial.print("0");
if (address < 16) Serial.print("0");
Serial.print(address, HEX);
Serial.print(":");
Serial.print(" ");
if (value < 16) Serial.print("0");
Serial.print(value, HEX);
// Procedure to write to the AT28:
// Set OE and WE high
// For each address, write the address and data, then pulse WE low
void writeEEPROM()
Serial.println("");
Serial.println("***** WRITE *****");
digitalWrite(AT28_CE_Pin, LOW);
digitalWrite(AT28_OE_Pin, HIGH);
// Set the data pins for output
for (int i=2; i <= 9; i++) pinMode(i, OUTPUT);
for (int address=0; address < ADDRESS_MAX; address++)
byte value = pgm_read_byte_near(values + address);
printValue(address, value);
writeShiftRegister(address);
// the (i + 2) translates from bit # to pin #
for (int i=0; i <= 7; i++) {
digitalWrite(i + 2, (value & (1 << i)) ? HIGH : LOW);
// Send a pulse to the AT28 to write the data
digitalLow(AT28_WE_Pin);
digitalHigh(AT28_WE_Pin);
delay(10);
// Procedure to read from the AT28:
// Set OE low and WE high
// For each address, write the address, then read the data
void readEEPROM()
Serial.println("");
Serial.println("***** READ *****");
// Now read each address value and print out.
// Set the AT28 for "READ", WE high, OE low
// Set the data pins for input
digitalWrite(AT28_WE_Pin, HIGH);
digitalWrite(AT28_OE_Pin, LOW);
for (int i=2; i <= 9; i++) pinMode(i, INPUT);
int value = 0;
if (digitalRead(i + 2)) value += (1 << i);
Serial.println("");
void setup()
Serial.begin(115200);
pinMode(SER_Pin, OUTPUT);
pinMode(STCP_Pin, OUTPUT);
pinMode(SHCP_Pin, OUTPUT);
pinMode(AT28_CE_Pin, OUTPUT);
pinMode(AT28_WE_Pin, OUTPUT);
pinMode(AT28_OE_Pin, OUTPUT);
// Disable the AT28
digitalWrite(AT28_CE_Pin, HIGH);
Serial.println("***** TESTING *****");
testShiftRegister();
// Wait until user hits return.
Serial.println("***** Hit <RETURN> to start WRITE/READ *****");
while (Serial.available() == 0) {};
Serial.read();
writeEEPROM();
readEEPROM();
void loop()
// Do nothing
