It is currently Sun Nov 24, 2024 2:29 am
 Post subject: MOS 6529 replacement?
PostPosted: Thu Oct 09, 2014 8:34 pm
Hello I'm fixing a Commodore 16 and I need to replace the MOS 6529B (datasheet) that handles keyboard communications. Is there a modern compatible solution (preferably single chip) that I could use, perhaps with TTL chips?
PostPosted: Thu Oct 09, 2014 11:23 pm
The 6529 resembles a 6520 or 6521 PIA with only one output port. That might be worth looking at, since it's not very likely you'll find an exact replacement readily available.
PostPosted: Fri Oct 10, 2014 2:30 am
hello Yrouel, and welcome. :)
if a single chip alternative is possible I think it would have to be some sort of programmable logic -- a CPLD or perhaps a PAL or GAL. I'm sure a CPLD could do it but you might prefer not to go that route. Depending which product you select, the form factor and pinout might not match the original, so you'd be obliged to hack together some sort of adapter, even though you're only dealing with a single chip.
You might prefer to build an equivalent circuit using 74xx series logic ICs. Various solutions are possible but certainly you would need at least three or four ICs. For example, the input function could be done by a 74hct245 or '244, and the output function could use a 74hct377 (octal D flipflop with data enable). Then there'd be a couple of 74LS07 to serve as Open Collector buffers for the '273. That's not quite 100% complete, but do you see the basic idea? Do you have the skills to build such a thing? If it's something you're comfortable with then I'll describe the details.
BTW it might be helpful if you could direct us to a schematic for the Commodore 16.
cheers,
PostPosted: Fri Oct 10, 2014 2:44 am
I was aware of the 6529's existence but never paid any attention to it until now. Wow, it's simple! There's not even a phase-2 input, and no data-direction register. It just uses open-drain outputs instead so if you want input, you just quit pulling the output down, like for I²C. You could do it with discrete logic on a tiny board.
PostPosted: Fri Oct 10, 2014 3:56 am
The 6529 is little more than a dumb bus transceiver, so perhaps something like a 74xx245, with a little glue logic for chip selects, etc., could be pressed into service.
PostPosted: Fri Oct 10, 2014 4:17 am
Wow, it's simple!
It's not that simple, BDD. Unlike a transceiver, the 6529 has an output latch that captures & retains write data -- check out the Write Cycle Timing Diagram. So you'll need more than a 74xx245 with a little glue logic. The recipe isn't complete without a byte-wide latch or flipflop. (And Open Collector buffers, of course, but maybe that falls in the "glue" category.)
PostPosted: Fri Oct 10, 2014 8:38 am
Yes I'm comfortable building some compatibility board, it's the design part I'm lacking of :(
Here the service manual for the C16 which also contains schematics.
Looking at 74xxx logic I found the 74xx573 (datasheet), can it be used alone?
PostPosted: Fri Oct 10, 2014 1:17 pm
No, you will need more than that. But I think a three-chip solution might be possible. That means using discrete logic on a tiny board as Garth suggested. You would remove the 6526 and run 20 connections from its location to the new board. The wires going to the new board should be kept reasonably short -- 10 inches, maybe, or less if you can manage it. Does this sound doable?
But first it's best to ask why you believe the 6529 is defective. What symptoms did you observe, and what tests did you run? Naturally I'm trying to be helpful, not critical. The problem might lie elsewhere, in which case the effort of building a new board would be wasted -- and the problem would still remain! :cry: :cry: :cry:
PostPosted: Fri Oct 10, 2014 2:29 pm
The C16 boots fine and I see the ready prompt but the keyboard doesn't work. The C16 boots fine also without that chip installed (I already socketed it) so at least is not a vital chip.
I tested the keyboard in a C64 (I have only one C16) which while not perfectly compatible showed me that pressing random keys produced some output so I'm fairly confident the keyboard itself works. I checked continuity on the connections on the board and it seems all fine.
Being the 6529 used between the keyboard and the rest of the bus my best bet is that's the issue here.
As the board goes I should have a 20 pin wire wrap socket which should then be long enough to plug a board directly on the socked on the C16 motherboard (or I'll use something else for the same purpose). I already had to do something like that for the adaptor to replace the PLA with an EEPROM.
PostPosted: Fri Oct 10, 2014 3:09 pm
Okay, what you're saying seems reasonable. Question, though -- do the joysticks work properly?
As I see it, the 6529 drives the keyswitch matrix, which, if a switch is pressed, sends a logic low signal to the TED chip -- whatever that is; I'm not a Commodore expert! :D My point is, maybe it's the TED chip which isn't working -- and the joysticks would reveal that. That's because, in addition to the keyboard, the TED chip also receives logic lows when the joystick is used. So if the joysticks are OK then that's a sign that the TED chip is working.
BTW "not working" doesn't necessarily mean defective. Both the TED chip and the 6529 require signals such as chip select which come from elsewhere. Before we build a new board, let's be 100% sure it's the 6529 that's defective -- not the TED, or the chip-select circuitry or whatever.
Also BTW, it seems to me the read (input) function of the 6529 isn't used. :!: Can anyone give a second opinion on that? Yes they've made a connection to the R/W pin, but I can't imagine how reading from the 6529 would serve any useful purpose -- I believe it's only ever written to. Thoughts?
PostPosted: Fri Oct 10, 2014 3:17 pm
I can't test the joystick ports at the moment since the C16 has a different connector than the C64 (and other machines of that era) so my joystick can't be connected. However I'm fairly sure that TED is working, if it wasn't I would've other issues since it handles a lot of stuff in the system like the video.
PostPosted: Fri Oct 10, 2014 3:20 pm
Maybe I'm just being a bit goofy, but wouldn't the best replacement for a MOS 6529B be another MOS 6529B?
There should be thousands of them floating around the world, and hundreds of them should still be within your reach, no?
Mike
PostPosted: Fri Oct 10, 2014 5:29 pm
That's not 100% conclusive, although it is reassuring. But remember it's possible some parts of the TED chip work and others don't. We also haven't ascertained whether the 6529 is getting a proper chip-select signal -- or, as Mike says, whether it might be easiest to test it simply by replacement!
But you seem eager to proceed, so here's my version of a 6529 replacement. Just understand I can't promise this'll work, because:
  1. it's possible the original 6529 is not defective
  2. the data sheet is vague on certain details
  3. although I doubt it, I may be wrong about the C16 not using the 6529's input facility (as noted in the last paragraph of my previous post). 2nd opinion anyone? I have omitted that functionality to simplify the board.
Regarding point b, one thing the datasheet doesn't say is whether the output data gets inverted. I assume not, but if it does then simply take out the 'LS07's and use 'LS05's or 'LS06's instead. You're gonna use sockets anyway, right? :wink:
http://www.nxp.com/documents/data_sheet/74HC_HCT377.pdf
PostPosted: Fri Oct 10, 2014 7:01 pm
74ls647 :)
PostPosted: Fri Oct 10, 2014 7:21 pm
@Dr Jefyll thank you very much, it'll be few days since I gather the parts for it I'll let you know as soon as I've tested it :)
@grzeg that chip seems very promising, thanks
