It is currently Sun Nov 24, 2024 1:04 am
PostPosted: Fri Aug 15, 2014 8:40 pm
While I could do some experiments to try to determine the behavoir I was wondering what best practise is.
I'd like to add a 65C22 to my micro for the purpose of:
:arrow: Generic parallel IO via a header; or
:arrow: 2 9 pin joystick ports
(Amongst other things, like the timers and serial input to a keyboard.)
I read (not on the datasheet) that inputs float high. So is it reasoanable to not use external pullups? With external pllups I can't make the port general purpose (ie. useable for outputs via the header when the joysticks aren't plugged in.)
If I need external pullups I'll probably scrub the joystick ports, since putting the 2 ports on general purpose headers sounds more useful.
PostPosted: Fri Aug 15, 2014 9:00 pm
On non-WDC VIAs, inputs offer an LSTTL load. This is true even of 65c22's from Rockwell. An unconnected LSTTL input is basically high. The loading presents a problem for some applications. I definitely recommend using WDC's which not only have true CMOS inputs, but also bus-holding devices, so floating inputs are not a problem.
WDC's also have very strong output drivers. I have tested Rockwell and WDC 65c22 outputs here, and they are many times as strong as the data sheet says (and I believe the processor has the same output circuits). In my experiment, WDC's outputs were able to pull to within 0.8V of either rail with a 220-ohm resistor to the opposite rail, meaning a 19mA load, even pulling up, and give 50mA into a dead short. Rockwell's could pull down with 100mA into a dead short, but could not pull up as hard, not being symmetrical like WDC's.
Users browsing this forum: Google [Bot] and 34 guests
