Something bothers me about that datasheet MichaelM mentioned... although this datasheet is extremely informative, the pin assignments are rotated 180 degrees from expected when looking at the socket's from the top (as if you could see through the socket). Why is that so, and wouldn't that throw someone off who wasn't paying close attention to the datasheet?
https://www.mill-max.com/assets/new_pro ... 43-145.pdfAdditionally, various other datasheets that I've found seem to expect a hole size of approximately 0.8 millimeters, which is smaller than the 0.036 inches (0.88 mm) suggested here. For the part I developed in DipTrace, I used 0.8 millimeters for the hole size and 1.1 mm for the pad size... I image 0.3 mm should be enough pad space.
Not sure if the silk screen will even be visible when all is said and done, however
