It is currently Sat Nov 23, 2024 11:57 pm
PostPosted: Sun Oct 13, 2013 6:56 pm
I finally hooked all parts together that I was planning for the first simple system.
It's using a W65C02, a AT28C64 eeprom, a 74HC138 for address decoding and a 6532 RIOT I got from Jameco some weeks ago.
Serial I/O is done with a MC6850 that is easy to connect to a 6502 bus and also easy to program.
The whole thing runs at 1.8432 MHz to use the main clock also for the serial clock. It's a bit to fast for the R6532, because it's the 1MHz version, but the system seems stable.
Now I need to write proper code for this thing and then it will be moved to a prototype PCB.
From now on I can truly say that I've build my own system from scratch. After nearly 30 years this idea has come to life. :mrgreen: :mrgreen: :mrgreen:
Mario.
PostPosted: Sun Oct 13, 2013 8:07 pm
Great! You show it can be done!
PostPosted: Sun Oct 13, 2013 8:20 pm
Mario.
Good job! Looks as though designing and assembly your unit was a real RIOT. :? :lol:
PostPosted: Sun Oct 13, 2013 8:23 pm
Totally cool Mario. Same as me. :) Waited not quite 30, maybe 25 years to finally do it. Nearly cried when those LEDs starting flashing, the first time I applied power:
http://www.youtube.com/watch?v=TXWvmcBsQn0
Mine's a 6809, AT28C256 (own built EEPROM programmer), 6522, 6850, etc. Going to try integrating a AY 8192, so the baby can make some noises, next...
Makes a change from the day job of perl programming I'll say. ;)
Lawrence
PostPosted: Mon Oct 14, 2013 7:42 am
Congratulation from here, too! Now you need a sticker for your MacBook that says "My other computer only needs 128 bytes of RAM" :D .
Users browsing this forum: Google [Bot] and 99 guests
