It is currently Sat Nov 23, 2024 10:04 pm
 Post subject: 6502 friendly LCD module
PostPosted: Mon Dec 17, 2012 4:09 am
Looking at what ebay offers I stumbled across this:
http://www.ebay.com/itm/370677559036
It is cheap, and it even offers touch interface. As for the technical part, it has an onboard LCD controller. I googled it a bit and I found out that the SSD1289 chip on the module has lots of options on how it is being interfaced. One of them is the 6800 bus, and that means that it could be directly accessed by a 6502!
Hackaday article:
http://hackaday.com/2012/07/05/library-for-driving-ssd1289-lcd-displays-with-small-microcontrollers/
Datasheet:
http://www.kosmodrom.com.ua/el/STM32-TFT/SSD1289.pdf
Since it is so cheap, I was thinking that I could maybe buy it and thinker with it a bit.
PostPosted: Mon Dec 17, 2012 5:28 pm
Specifications:
http://www.icstation.com/ebay/3.2%20TFT%20LCD.zip
They are a bit confusing, and I can't figure out if the data interface is 5V tolerant or not.
PostPosted: Mon Dec 17, 2012 5:36 pm
This is what google translate gives me when i try to translate the Chinese document:
3.2-inch TFT
http://ttmcu.taobao.com
The test program wiring instructions:
The code testing environment: JME-core board the STC microcontroller instruction cycle +1 T (51 cores
STC12LE5A60S2) +33 the M crystal MCU operating voltage 3.3V
The program default IO connections:
The Line of Control: RS-P3 ^ 5; WR-P3 ^ 6; RD-P3 ^ 7; CS-P1 ^ 0; REST-P1 ^ 2;
Data line: DB0-DB7 in turn connected P0 ^ 0-P0 ^ 7; DB8-DB15 turn connected to P2 ^ 0-P2 ^ 7;
The touch function connection: (do not use touch from time to connect)
D_CLK-P1 ^ 7; D_CS-P1 ^ 4; D_DIN-P3 ^ 0; D_OUT-P3 ^ 1; D_PENIRQ-P3 ^ 4;
● TFT power: the screen power supply 2.8-3.3V; remember not to use 5V
(With the PCB module has inherited 3V regulator IC can enter 5V)
● backlight power supply (LED_A pin): backlight power maximum 3.2V
(Series 200 ohm resistor in series 20 ohm current limiting resistor or 5V 3.3V supply).
● data port level: in theory, can not let the data port level exceeds 3.3V, 5V microcontroller If you must use
The IO connection data bus, because tft internal voltage clamp, with can be used, however always is not standardized.
Experiment can do sample testing, bulk products, best to improve product stability,
Low-voltage microcontroller or add a level conversion IC.
The text is a bit confusing, but it seems data lines must be 3.3V, but what about power supply?
PostPosted: Tue Dec 18, 2012 10:47 am
I contacted the guy from the Hackaday article, and hopefully talking to him will help figuring out this module.
Since it is rare to find such a module so cheaply, I went on and I ordered it, so Ill be posting more about it when I get it.
PostPosted: Sun Jan 13, 2013 10:15 pm
Do you have any update on this? I am also looking for a cheap LCD with touch to connect to a 6502.... (although I'd like to go a bit larger, say 5")
PostPosted: Sun Jan 13, 2013 11:07 pm
I ordered it, but I am still waiting for it to arrive.
PostPosted: Fri Mar 01, 2013 12:42 am
I wouldn't necessarily call these modules 6502 friendly however they seem a decent bet to get color graphical output on to a 6502 based project. These kinds of modules are available fairly cheaply off eBay up to around 7-8" size and up to around 800x480, the difficulties I see are 1. level conversion to 3.3v I/O, and 2. driving their controller chips, generally Epson SSD1963 and the like.
I think an easier way than trying to make a 65-series chip drive one of these directly might be to use an AVR. Arduinos can drive these displays with a level converter shield and there is already a library of software for doing text and graphics primitives. The LCD can actually be mapped into the AVR's address space on an ATMEGA 128/1280/2560 and these chips can also be run at 3.3V. Being 5V tolerant, they might also serve to do level conversion.
I've been thinking about trying something like this and I have an ATMEGA128l breakout on order, but I am new to AVRs (as opposed to being only mostly new to 65xx) and was wondering if anyone else had considered this combination?
PostPosted: Fri Mar 01, 2013 1:52 am
tet00, current-production 6502's are spec'ed from 1.2V to 5V, and I think several people here are running them at 3.3V. There are various simplish ways to convert the voltages anyway like with 74LVCxx although of course it's much easier if you have a synchronous serial interface (like SPI) so there aren't so many lines to do, and each one is unidirectional. I don't see it as being any problem at all.
PostPosted: Fri Mar 01, 2013 10:02 am
tet00 wrote:
...on an ATMEGA 128/1280/2560 and these chips can also be run at 3.3V. Being 5V tolerant, they might also serve to do level conversion.
They are not 5V tolerant if they run at 3.3V. The usual clamping diodes limit the voltages on any input pin except reset & xtal1 to .5V above or below the operating voltage.
PostPosted: Sat Mar 02, 2013 2:26 am
tet00 wrote:
I wouldn't necessarily call these modules 6502 friendly however they seem a decent bet to get color graphical output on to a 6502 based project. These kinds of modules are available fairly cheaply off eBay up to around 7-8" size and up to around 800x480, the difficulties I see are 1. level conversion to 3.3v I/O, and 2. driving their controller chips, generally Epson SSD1963 and the like...
I've used a Newhaven Display with the SSD1963 controller IC, except it's made by Solomon Systech. The IC has a pin to set it to 65xx mode or 80xx mode.
I've used their 7" 800x480 display with the WDC65C02 in a project I've posted here somewhere, running Arlet's softcore 6502 @38MHz using a Spartan 3. I've also used their 640x480 display. I had that hardware successfully running @20MHz with external 10ns asynchronous RAM and a WDC65C02. System volts @3.3V. BTW ~ 40MHz is the fastest these display can go.
Users browsing this forum: No registered users and 51 guests
