It is currently Sat Nov 23, 2024 8:22 pm
PostPosted: Tue Feb 07, 2012 4:57 pm
Probably most of you (if not all) use more modern SPI/I2C based
RTC chips these days. However, for those who might me interested,
I publish the way to attach mux-bus based RTC chip (e.g: DS1685/1687,
Intel 8051 type of architecture with ALE strobe pin to latch multiplexed data/address)
to the non-multiplexed (separate) parallel addr/data bus system (like 6502).
Details are here:
http://6502cpu.blogspot.com/2012/01/mkh ... 85-or.html
Bottom line: Don't be tempted to synchronize /WR and /RD signals with
PHI2 signal. That IC does not like it and the timing will not be right.
It is OK to synchronize chip select signal with PHI2.
Cheers!
Marek Karcz
"Don't worry. We've got our best people working on it."
