Controlling 4 injectors? I don't see the drivers...
Yes, 4 injectors , at that moment i use mc33385 (at upper left side) to drive injectors independent.
Old board use 2 pieces VNP5n07 - smartfet , one transistor drive 2 injectors per bank.
Are you running your fuel mixture more rich or more lean? Fuel additives?
Currently I am using this system in my amateur racing car , so the fuel mixture is more rich than lean. To tune the fuel maps i use wideband oxygen senor and AFR type device, by which I can see what is happening with the exhaust gases
My youtube channel :
http://www.youtube.com/user/swietyEFI?feature=mhum
Engine tuning - old ecu:
http://www.youtube.com/user/swietyEFI?f ... QSAk3csDwc
