Yes, making progress. I guess I was sleeping through the last page of posts.
BTW, the probes say x10 / x1 60MHz on them
They're only 60MHz in the x10 position (ie, the switch on the probe itself in in that position). In the x1 position they're probably only good for a couple MHz. Do take care of them. Good probes are not cheap to replace. And yes, the 'scope and probes will have to be good for many times your maximum frequency to semi-accurately show what's going on in your square waves, because of the harmonics it takes to form them.
You can make the pictures show up in the post itself by doing:
[im
g]<picture_URL>[/im
g]although I hid something else in there to make the tags show and keep them from trying to do their job. I had to leave the "Disable BBCode" box unchecked so the [qu
ote] above would work.
If your half meter of wire is between the 9V battery and the regulator, and the regulator has input capacitors, it's ok.
