Not really 6502, but maybe relevant to this thread.
Abuse of 74AUC2G53 Inhibit pin allows for one less gate.
If it doesn't make sense, just ask. Not my clearest drawing.
Series prefixed Manchester Carry, Borrow, or Magnitude.
Karnaugh 0110 XOR for addition, 1001 NXOR for subtraction.
Propagation rules can be inferred from the Karnaugh map.
No wasted time or control line to XORvert the B input.
Generate and Annihilate are not wired as constants here.
Determined by replacement rules LessThan and GreaterThan.
Allowing < = > magnitude comparisons, A-B, B-A, and A+A.
A+A RLTC isn't using addition, but leftward replacement.
Rotate Right TC relies on an external reversing loopback.
RP loops back to reverse order 76543210 ~ 01234567.
No attempt made to flip a reversed result back to normal.
Just keep Rotating Left Through Carry (your other right).
These rules neck down to a single capacitive load when inhibited.
So not to burden a long chain of tranmission gated propagation.
I also triple 1G66 propagation gates to better handle fanout...
CBT doesn't switch as fast, but far less series resistance.
Not entirely sure AUC is better. Depends chain length.
