sburrow wrote:
Because of the enormous cost of larger 4-layer boards, I refuse to go above the 10cm x 10cm mark, ever. If it doesn't fit, then I need a second board [...]
I'm not opposed to using a second board, either.
But once again there are both pros and cons.
I'm just sharing my personal thoughts on the matter. Indeed there are pros and cons, but at my stage, if it doesn't fit on one board with auto-router, then I'm probably allowing feature creep to set in. Heck my third board coming soon has PS/2 Keyboard, a SNES controller port (which is hunkin' huge), and tons of plug-and-play ports.
And of course this is coming from the guy who refuses to spend $40 on a EPROM programmer, no more than $8 on a board, yet will spend over $100 on chips! Take it with a grain of salt.
I am moving toward 4-layer boards as well, but looking at 57 board designs I did in 2019, 58 designs in 2020, and 25 designs in 2021, I can only find four 4-layer designs, all done in later half of 2021 when 4-layer pcb became affordable. The other 136 2-layer designs worked just fine, except one 68020 motherboard with 16-meg dynamic RAM that generated excessive refresh noise which was promptly fixed with a 4-layer design.
Bill, I didn't know you were so... prolific!
