Oneironaut wrote:
How popular is CC65?
I was thinking about making .S libraries for all of my Vulcan Commands so that games and demos can also be done in C.
On my AVR systems, doing this made them much more popular (and easy) to use.
It has been around six years since I played with cc65, but when I did I was extremely disappointed at the quality of code it produced. Not only was execution speed disappointing, but it was ghastly in terms of bytes used. You wouldn't be able to write a very complicated game and have it fit in 64K.
I'm not a big Forth user myself, but from what I do know, it would make a much better choice than compiled C on the 6502 because the code would be much more compact and likely just as fast as the compiled C code.
If you dislike Forth, another option would be to use one of the several C compilers that compile to p-code. They may not be as fast as cc65, but they will make up for that with the compactness of their code, which IMHO is an important consideration when you only have 64K of address space to work with. Now if you want to throw some more 74HC logic chips at the problem, you can probably make a decent MMU and then hack up the compiler runtime to work with it as yet another alternative...
