... I see that relays in small bulk are available for around 20 cents each for SPST types.
Do you have a link? The cheapest I have seen is $0.99. I have enough for this project, but if it goes well I might do something crazy (e.g. The world's worst math coprocessor for the 6502). Even a modest decrease in cost would make it more approachable.
The other main thought: do you use a single type of relay throughout (spst?) or do you experiment with dpst (or more poles) or with latching relays? Do you use a single logic 'gate' type, or do you get creative with routing voltages (and directions!)? The opportunities are endless.
Most of the relay projects I have seen online standardize on a single relay to ease PCB design and construction. That way you don't get confused and wire something wrong because the relay had a different pinout. Latching relays would seem a natural fit for building registers, but I haven't seen them used.
Harry Porter's machine standardized on four pole double throw relays because he could use two relays for the enable logic to control the bus. He also had a standard wiring that allowed a single relay to have multiple logic function outputs. I imagine that came in handy because sometimes it's handy to have both the AND, NOT, and OR simultaneously available.
True story. I discovered his machine because of a typo. Years ago I was trying to search for Harry Potter, and replaced a t with an r. I then spent hours studying his machine, and never redid my original search. I emailed him and he got a laugh out of it.
@Garth, wow, that capacitor coupled with a resistor is a really flexible circuit element.
