Bill, et al,
Years ago I built up a dozen mini headphone amps and mini DACs for audio use. These were designed by Ti Can and his website is amb.org.
Both of these neat little devices are housed in a Hammond 1455C801 extruded case. The PCBs are a standard Euro size. The mini DAC required 2 PCBs which were plugged together and slid into the case. The case size is: 80mm x 54mm x 23mm. Pics attached:
For my Pocket SBC, the upper PCB will contain:
W65C02S in QFP
SC28L92 in QFP
RAM in TSOP-44
Flash NAND in PLC44 (in SMT socket)
DS1501 in SOIC-28
EPM240T100 in QFP
SMT Clock oscillator
SMT Xtal for DUART
SMT Resistor pack
SMT caps for bypassing, etc.
SMT socket for Microdrive flat cable
10-pin JTAG connector (possibly in 2.0mm header)
Header connectors to lower PCB
The lower PCB will contain:
FTDI USB to UART SMT interface
5.0V to 3.3V SMT regulator
TL7533 Reset chip in SMT
DS1233 Panic (NMI) chip in SMT
Mini-USB connector for console
Mini barrel connector for 5V power
3 LEDs for indication
two momentary switches
one power switch
one header for second serial port
one header for GPIO (DUART port)
usual bypass caps, resistor, etc. (all in SMT)
Header connectors to upper board
Note: Microdrive will be shock-mounted to lower PCB. Both PCBs will be 4-layer.
Hope this is more clear in what my goal is for the Pocket SBC.
