Hi everyone,
i have a working FDC interface for 1.44MB diskette, look at this project:
http://65xx.unet.bz/I used a chip found in some old PC-XT old FDC boards: the UM8388, clocked at 24MHz, able to handle 500Kb/s rate (1.44MB) or 250KB/s (720 Kb).
In my project i used a DMA chip (82C37) but is not mandatory: the 8388 can be programmed both in DMA mode/not-DMA mode. In the last case the time between 2 consecutive fetch of data from FDC should be not greater than 12uS, otherwise a loss of data happen (i interfaced the UM8388 with a 65816 clocked at 4MHz without problems).
In the past i tried some tests with the WD1772 clocked at 16MHz (but take care: WD1772 datasheet say clock should be at max. 8MHz), and worked fine for format/read/write 1.44MB diskette.
Programming UM8388 is very easy because have commands for format tracks, read/write multiple sectors. calibration of track 0, while WD1772 need more effort (both need a double-step calibration for format 80 trcks diskettes).
