It is currently Sun Nov 24, 2024 1:02 am
 Post subject: Re: 65C02GPD v2
PostPosted: Sun Jan 17, 2016 10:56 am
cbscpe wrote:
Even if the actual frequency of the interrupt is 128Hz and not 100Hz it still can be used, you just need to take that into account, or am I wrong on this?
Sure. It's only a issue of you want to record the passege of time as a whole number of seconds and milliseconds, or whatever. But you could use seconds and 128ths of a second, it's just less convenient, especially if you want to display it.
PostPosted: Sun Jan 17, 2016 12:49 pm
You can get a decent approximation of a second and centisecond (1/100th of a second) counter using the following method:
  1. take a single byte counter, and add 200 to that counter every 128 Hz timer tick
  2. when the counter overflows (carry=1), add 1 to the centisecond counter.
  3. when the centisecond counter reaches 100, reset it to 0, and increment second counter.
Fairly simple to implement in 6502 assembly.
PostPosted: Sun Jan 17, 2016 1:09 pm
That's clever! Isn't it in fact exact? You're counting in units of 200/256 which is exactly 100/128.
PostPosted: Sun Jan 17, 2016 1:25 pm
The second counter is exact, but the centisecond counter has a bit of jitter.
PostPosted: Sun Jan 17, 2016 1:32 pm
Ah, right - frequency is spot on, but phase wanders a bit.
PostPosted: Sun Jan 17, 2016 1:39 pm
After 2 ticks, 2 * 1/128 seconds will have passed, but only 1/100 of a second will have been counted. It's still very very clever.
PostPosted: Sun Jan 17, 2016 4:09 pm
If you are using a counter that is incremented or decremented with each jiffy you simply start at $00 or $80 and go from there. In the former case, when it hits $80 or in the latter case, when it hits $00, you'd reset the jiffy count and bump the seconds.
As long as the jiffy count has no special meaning to anything other than the routine that maintains the time, I don't see any reason why an odd interrupt rate would be a handicap. That said, the POC's BIOS returns the instantaneous jiffy count when the GESUTIM (get system uptime) function is called, which gives the uptime a 10 millisecond resolution. For that reason, use of a time base that increments exactly at 10 millisecond intervals is necessary if the return count is to be accurate. That's where the counter/timer in the 28L92 comes in.
Users browsing this forum: Google [Bot] and 46 guests
