It is currently Sun Nov 24, 2024 6:09 am
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Sat Jul 31, 2021 4:17 pm
Here is the first iteration. It uses 3 dual pot rams now - one for the character value, one for foreground and one for background. So in the end you should be able to define foreground and background color of each character. It also sprouts basic ROM and 512 MB character RAM (simply because I have those chips lying around)
vga_text_v01.pdf [455.26 KiB]
Downloaded 41 times
PostPosted: Thu Apr 28, 2022 10:13 pm
Again - it was a very long time since the last post - but the project is still alive. Actually it's better than alive, it's working. This is a test image of pure TEXT output.
Here's how it looks like on a breadboard:
I attached the schematics as well.
Now why did it take so long?
    it was complicated - far more complex than I imagined
    if you have only 30-60min each day at night when you are tired progress is slow
    you don't have any time to yourself during Christmas vacation :P
    you are bound to make many mistakes, and motivation to debug sometimes is low
    especially when something works, than does not work next day
    only after I discovered load from a logic analyzer might positively impact your design things became more stable
    pull-up resistors are better stabilizers than load from a measurement device
happy hacking
Michael
File comment: schematic in BW
vga_text_v02_bw.pdf [587.07 KiB]
Downloaded 36 times
File comment: schematic in color
vga_text_v02_color.pdf [599.32 KiB]
Downloaded 33 times
PostPosted: Fri Apr 29, 2022 12:05 am
Ha ha. Nice work. Regarding lack of time, I know the feeling, we often have other things to prioritise over our hobbies. But the hobbies are still there for us when we get back to them. Sometimes they even still work!
PostPosted: Sat Apr 30, 2022 1:01 am
Mighty fine work!
PostPosted: Sat Apr 30, 2022 1:25 pm
Thanks Brad, actually I copied the Graphic part from your design :)
PostPosted: Tue May 17, 2022 4:11 am
The PCB I created (and ordered from China) worked mostly. Here are both cards combined showing text output
and here doing graphics
There are 2 problems still. Column 0 of the text output is not 100% correct, some timings seem to be off. Far worse is an issue caused by the 4 Y address lines connecting the 2 boards. If they are directly connected via short pin headers the output goes black. If I connect them via 40cm wires as shown in the pictures it's working. Either reflections, or timings, or cross-talk is causing an issue here.
Still as "proof of concept" this worked out. But I probably would not repeat this exercise and instead use one or more CPLDs or even a FPGA for my next iteration. There are simply too many chips in this "bug cemetery" :)
Users browsing this forum: No registered users and 39 guests
