Well, I built a 20 mil (really TTL) to RS-232 adapter for my AIM.
I used a MAX232, and connected it according to the app note, which recommends using 1uf caps in the voltage doubler circuit.
I connected pin U on the 44 pin edge connector (TTY out) to pin 11 on the MAX232, and pin 14 to Rxd on the RS232.
I connected pin y on the 44 pin edge connector (TTY in) to pin 9 on the MAX 232 and pin 8 on the MAX 232 to RS232 Txd.
I connected the unused inputs (pin 10 and 13) on the MAX 232 to ground so as to not have floating inputs.
Did a continuity check with all connections and a voltage check, all seemed well.
I then connected it up to a terminal emulator at 2400 baud and inited the locations on the AIM for 2400 baud.
I've tried 1200 baud, and 2400 baud, 8 bits 1, 1.5 and 2 stop bits, odd, even and no parity, 7 bits, 1, 15, and 2 stop bits, odd, even an no parity.
When I transfer control from the AIM to the TTY in/out, nothing happens, no in, no out. I then press the space bar on the AIM and it starts sending characters, but all I see is y0' on the terminal display. When i put the KB/TTY switch on the AIM back to KB, the characters stop.
Any clues, where should I look next?
Any help or suggestions much appreciated,
AndyD
