Individual_Solid wrote:
It all works. [...] this revision has fully come to life.
Wow -- really? I'm glad, of course. But you seemed to have some pretty strange glitches on SYNC. These could perhaps be an artifact of your 'scope setup, and have no functional implications. But unless these can be eliminated or at least explained I'm left with a nagging feeling that all is not yet well.
I
think that weirdness (at least, in the second screenshot you posted) comes from the CPU starting up and then being pulled back into RESET.
I just took some shots of a trace with the now functioning RESET circuit.
This is showing mostly NOPs with an occasional register decrement. This is a little noisy, but I'm definitely attaching the probe grounds a little far from the signal source. Do you still see something I should be worried about? I can do a trace from power-on again, if that's worth while.
