Welcome!
MarkBolton wrote:
Is this a capacitive problem or possibly a ground problem?
My first questions have to do with your oscilloscope probe. I hope you are using the X10 ("times ten") setting, as this results in the probe having much less capacitance (compared to X1) and thus less chance of the probe disturbing the circuit it's measuring. Also, it's important that your circuit's ground be attached to the ground lead on the end of the 'scope lead. IOW don't rely simply on an alternative connection that somehow attaches circuit ground to the scope itself.
I have connected GND from the TTL to USB with GND of the whole circuit.
A photograph would be helpful. That's because the actual routing of ground and power connections can make a difference with wonky problems like this!
