It is currently Sat Nov 23, 2024 5:00 pm
 Post subject: UART
PostPosted: Sun Nov 25, 2007 1:03 am
After not receiving a response from WDC concerning when the 65C51 would be available, I started looking for a replacement. I came across the Exar UART product line. Something that made it stand out immediately was the availability of a Motorola bus interface on some of the models.
I recently purchased a 16L580 from Future Electronics that has both Intel and Motorola bus interfaces.
This is a 32 pin QFN surface mount part that measures only 5mm square. I bought a Schmartboard adapter board and had it up and running on my SBC-3 core with only a little troubleshooting. I seem to be getting drawn into the whole surface-mount generation.
It has R/W, /CS, /IRQ, and /RES pins that connect right to the 65Cxx families. There is no PHI2 so the /CS needs to be gated with PHI2 externally. It is running well at 8 MHz and should be able to go even faster.
For those wanting a through-hole part, try the XR68C681. It comes in a 40 pin DIP package and has two UART's on board. Future Electronics has those in stock too.
Comments and questions welcome.
 Post subject: Re: UART
PostPosted: Tue Nov 27, 2007 5:05 am
I'm still really skeptical of surface mount components, personally. Particularly since a lot of the chips I am interested are increasingly only available in BGA packages. (e.g., SeaForth-24 chips are only 80 pins in size, but yet, at only a handful of millimeters on a side, you're looking at BGA packaging. :( ).
Can you describe in somewhat greater detail your experiences working with surface mount components so far?
PostPosted: Tue Nov 27, 2007 2:00 pm
Sure. I'll start a new topic for that discussion.
The info is now here:
viewtopic.php?t=1228
PostPosted: Wed Nov 28, 2007 12:24 am
Yes, BGA's will require some sort of reflow soldering.
I have this link as a possible solution from the ExpressPCB website:
http://www.stencilsunlimited.com/produc ... 08bb7379a4
PostPosted: Fri Nov 30, 2007 5:35 am
Hah, at my production volumes (specifically *one*), $145, not including "additional fees," is a bit steep. No thanks. :)
Users browsing this forum: No registered users and 54 guests
