It is currently Sun Nov 24, 2024 6:35 am
PostPosted: Fri Sep 13, 2019 1:47 pm
Currently I am designing few devices based on MOS6502/WDC65C02 CPUs.
I am going to use Motorola MC6840 timer circuit to generate interrupts and signals.
In particular I need:
1) Basic timer interrupt, to measure "system time". I'd like to implement something like millis() function from Arduino.
2) Square waves (without PWM, just standard 50% duty cycle) to generate basic audio "beeps" and to control stepper motors.
3) Pulse counting.
I've already read datasheet, but some things are still not clear to me.
1)I see there is no need to wire each timer input to system clock, if I want to use it to clock the timers. It could be distributed internally, from "E" pin. But what to do with unused timer inputs? Should I pull them up with resistors or simply left them disconnected?
2 Is it possible to use GATE input to "mute" its output, as it was done with Intel 8253 chip? If not, can I left unused GATE inputs disconnected or should I pull them up with resistors?
PostPosted: Fri Sep 13, 2019 4:59 pm
It would be helpful if you posted the datasheet or a link to it. This makes it a bit easier for anyone wishing to assist you. :)
Unused inputs should never be left unconnected with chips like this (MOS and CMOS). Tie them high or low, or used a resistor to pull them high or low.
cheers,
PostPosted: Sat Sep 14, 2019 4:53 am
cheers,
File comment: MC6840 Data Sheet
MC6840.pdf [1.46 MiB]
Downloaded 72 times
As is typical of NMOS hardware from that time, it's kind of slow and a bit weak in the knees.
PostPosted: Sat Sep 14, 2019 5:22 am
You might want to look into the W65C22S which is rated for much higher speeds, and from what you've written about your requirements, it can do everything you need (plus more). It's in current production too, with no end in sight. OTOH, if you just have some 6840's and you just want to have fun with them, there's nothing wrong with that, either.
Users browsing this forum: No registered users and 68 guests
