Ok
I wish to use the strobe pin of the LPT if possible
1.) The strobe pin is hardware controlled on SPP right?
2.) Is this ruffly the correct order of things:-
a. Date lines get data on them for 500NS
b. Then strobe pin goes from high to low for 1uS
c. Then the strobe pin goes from low to high again after 1 us
d. Then data is still present on the line for another 500NS ruffly??
help?? is this about right, I have found info on the Standard Parallel Port but I wanted to confirm info on the strobe pin, I'll have to have a play around myself but I just thought of asking first.
I want to use the strobe pin to clock an IC!
thanks
