It is currently Sat Nov 23, 2024 2:24 pm
PostPosted: Mon May 15, 2006 5:06 pm
Hi
I need to find a replacement for RTC M3003. I use this rtc in a board with 6502.
PostPosted: Mon May 15, 2006 10:08 pm
I could not find a datasheet for the M3003. National Semiconductor has a parallel access RTC chip that might work for you.
http://www.national.com/ds/DP/DP8573A.pdf
Or, check out the Maxim line of RTC chips.
http://para.maxim-ic.com/results.mvp?q= ... e%20Clocks
