It is currently Sun Nov 24, 2024 1:53 am
 Post subject: Bus Monitor PCB
PostPosted: Tue Oct 20, 2015 12:41 pm
The next version of Bus Monitor has arrived! I've created an RS232/command based one, spun it up in Eagle and had it manufactured.
Just got it back and spotted one issue (although not a show stopper): I'll need to run a mod wire from one of the chip GND pins as I forgot to link that part of the ground plane to the rest.
Abilities so far:
16 pins for 6502 address bus input.
8 pins for 6592 data bus input.
7 pins for signals input (active low, unless designated otherwise). Names settable through command line.
1 clock output capable of running in manual mode (push button), 1 Hz, 2Hz, 3Hz, 4Hz and 5Hz (not MHz) for diag. Mode settable via command line.
Set RS232 baud speed, safemode of 9600 in case of errors (hold down clock button during power up)
Load/Save profile information from/to EEPROM (signal names, etc.)
Following commands support:
CLS / CLEAR - clear screen
SHOW / SH - show data form buses/signals
CLOCK - set clock speed/conditon (HIGH, LOW, 1-5Hz). If set HIGH or LOW then clock button sneds 1uS pulse low or high.
RESET - reset the microcontroller
FORMAT / FORM - format the EEPROM for storing profiles
LS / DIR - list profiles stored in EEPROM
DELETE / DEL - delete a profile from EEPROM
SAVE / SA - save a profile to EEPROM
LOAD / LO- load a profile from EEPROM
COLOUR / COL - change the text colour
COM - change the comm speed settings
Most commands are complete, but I need to work on the SHOW command as this is what disapls the input from the various buses. I also need to implement a SIG command to set signal names.
This is my very first PCB design so I hope it works when I solder the on components :mrgreen:.
Pics:
File comment: Top side of PCB
File comment: Underside of PCB
 Post subject: Re: Bus Monitor PCB
PostPosted: Tue Oct 20, 2015 12:54 pm
Neat, what sort of applications do you intend to use it for? Tracing of a 6502 as it boots?
PostPosted: Tue Oct 20, 2015 1:22 pm
Can you please add the schematic for the pcb?
Mario.
PostPosted: Tue Oct 20, 2015 4:50 pm
It's main use is exactly that: when you've just built/prototyped a 6502 system this can be used to step through one cycle at a time and see what's on the buses and what the signals are doing.
I had a it made as I also wanted to see if I could design and have a board manufactured - I've designed proto-types, but never had one created as a PCB.
With regard to the schematic: please see attached.
I'll also be posting the firmware source code when it's finished. Basically, I'm making this open source for anyone to use.
PostPosted: Tue Oct 20, 2015 6:03 pm
Seems that your're using the 74AC245 only in one direction. Why not connecting the "dir" pin of all to one pin of the ATMEGA too? You could then read and write to the bus. But a cool project and rather complex for the first pcb.
Hope everything works as expected.
What tool did you used for the pcb? It looks bigger then half an euro board, so Eagle is out, as long as you don't have a licensed version.
Mario.
PostPosted: Tue Oct 20, 2015 8:53 pm
I really wanted to keep things passive for now given that this is my first proper PCB project. In future I'll see if I can do a more bus interactive one.
By the way, I did create this in Eagle free edition, using the maximum size allowed and double sided only. In future I might try to create something in Kicad as I sure as heck cannot afford an Eagle license (at least not the pro version).
Here's a few more pics of it soldered and actually working (just finished trying to clean the flipping flux off :roll:). Oh, and I did need to put in a link for the one of the buffer IC GND pins. Apparently it's quite normal to have one or two issues with a new board?
Top side:
Underside:
Plugged in (power + RS232 + ISP programmer):
PuTTY display via RS232:
PostPosted: Tue Oct 20, 2015 10:23 pm
I'm probably going to implement a menu command which will both show the bus and signal info and allow changing the clock speed at the same time.
Next stage: test using one of my 6502 projects! :)
PostPosted: Wed Oct 21, 2015 8:39 am
Nice job and it works. Having minor issues with the first version of a board is not unusual. You're running the ATMEGA with the internal 8MHz oscillator?
I like the Arduino Nano for such a job. You can get a clone for $3, it is really small and provides an USB Serial interface. So no need for a MAX232. And it runs on a true 16MHz clock.
I think I will try to create a similar board for testing and driving 8bit processors.
Mario.
PostPosted: Wed Oct 21, 2015 9:38 pm
Yep, I'm using the internal 8MHz oscillator. To be honest, I don't think you need 16MHz for this. In fact, 8 MHz is also OTT as well.
However, using an arduino nano is a good idea. I chose to go the 'naked' AVR route as I wanted an excuse to design and build my own board. All down to personal choice :).
With regard to writing back to the buses; What do you hope to achieve by doing this? I.e. do you want to simulate a ROM, RAM or otehr such device?
Users browsing this forum: No registered users and 57 guests
