It is currently Sun Nov 24, 2024 1:40 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
Which do you choose?
EPROM 11%  11%  [ 1 ]
EEPROM 89%  89%  [ 8 ]
Total votes : 9
 Post subject: Re: EPROM or EEPROM?
PostPosted: Fri Aug 28, 2015 11:48 am
nkeck72 wrote:
About the NVRAM and FRAM... to protect from malicious users (just to be safe) is there usually a write protect feature?
Edit: being the bonehead I can be sometimes, write protect comes in handy, especially when I mean to program $E000 (I/O) and actually type $F000 (ROM)
With NVRAM you can simply tie the R/W pin to +5V using a 3K3 resistor. Or (if you want to be able to write, but protect the contents against accidental erasure) you could possibly tie the R/W pin to, say, a latch or even a VIA pin (probably best to also have a 10K pull up resistor to deal with tri state before the VIA is programmed).
Something like this:
The only thing I'm not sure of is the need for the pullup resistor on the VIA_PIN line (R1). I've put it in so that you hopefully the NVRAM write pin will never enable writing (logic 0) spuriously (during boot/reset, VIA setup, etc.). As I say, it might not be needed, but its inclusion shouldn't cause any problems and it's best to be safe :mrgreen:. The use of HC or AC logic is recommended for the OR gate IC as you don't want to ahve to wait CPU cycles for the state of the VIA_PIN to affect the WE pin of the NVRAM when you decide to change it. Also, having the OR gate introduces a propogation delay which can possibly affect the maximum speed of your design. Fast=Good.
PostPosted: Fri Aug 28, 2015 9:46 pm
You could also add a hardware switch, operated manually, like the gizmo on floppy discs or SD cards.
PostPosted: Tue Sep 01, 2015 3:34 pm
Yes, I think you have to look after write-protect in your own circuit - the chips don't do it for you. You might for example want to write protect only the top part of the chip, containing the vectors and boot code.
Users browsing this forum: No registered users and 55 guests
