It is currently Tue May 21, 2024 2:15 am
 Post subject: Vector Pull - WDC65C02
PostPosted: Tue Apr 30, 2024 5:49 am
The data sheet I have states:
3.15 Vector Pull (VPB)
The Vector Pull (VPB) output indicates that a vector location is being addressed during an interrupt
sequence. VPB is low during the last interrupt sequence cycles, during which time the processor reads the
interrupt vector. The VPB signal may be used to select and prioritize interrupts from several sources by
modifying the vector addresses.
Is the reset considered an interrupt; that is, does VBP behave the same way? I may have an idea to drop IO into most of the top page of the memory, but overriding it back to eeprom/ram for booting and interrupts.
Thanks,
PostPosted: Tue Apr 30, 2024 7:39 am
Is the reset considered an interrupt?
Yes.
PostPosted: Tue Apr 30, 2024 8:35 am
Thank you!
PostPosted: Tue Apr 30, 2024 2:18 pm
To add a bit more it behaves almost exactly like an interrupt.
The first cycle 'fetches' the RESET op-code and sets SYNC (I tend to get a value of $FFFF on the address bus but I don't know where that comes from; the op-code fetched is ignored*).
The second cycle is doing an internal operation like any other interrupt (the address bus has whatever the last value the program counter was before the reset).
The next three cycles 'push' the program counter and status register onto the stack (but it does reads instead of writes; the stack continues from the value it had before the reset).
The last two cycles fetch the interrupt vector and $FFFC then $FFFD appear on the address bus.
* I don't think the first cycle is always $FFFF I vaguely remember that sometimes it is the old program counter and that it might depend on whether or not the reset happened whilst the clock was high. But I'm waaaaayy off in the weeds here.
cron
