GlennSmith wrote:
... and from the same document, this little snippet :
Thanks for
your post.
IMO, TI could have been more explicit with what they're saying. Let's be clear that they're talking about a situation where two different supply voltages are involved.
FWIW, let's look at the situation where there are NOT two different supply voltages involved (ie, if both devices are powered by the same voltage).
At the risk of stating the obvious, the pullup will hardly make any difference, because the totem-pole output will pull to the rail anyway. Although the pullup does appear in parallel with the upper FET, the FET's On Resistance is likely to be far lower than the resistance of the pullup, making the latter pointless.
