It is currently Sun Nov 24, 2024 4:21 am
 Post subject: New Reset circuit.
PostPosted: Fri Jun 02, 2023 3:22 am
I've seen a few posts recently where dubious reset circuits have been used and may or have caused problems.
I was always a fan of the DS1813, but they seem to have gotten relatively pricey so I tried some other circuits based on the 2N7000, but although it worked it really was out of spec. for the 6502. A few months ago I came up with he following based on the MCP100. I use the "H" variant with a threshold voltage of 4.475V and it works flawlessly. The added bonus is that it's 1/6 the price of the DS1813 going for less than $0.50 from DigiKey.
The resistor values are not critical as long as the supply is drawn down below the threshold voltage.
It provides power-on, push-button and brown-out reset of about 350ms or more. Effective, simple and cheap, who could ask for anything more? 8)
Update: Added some screen shots. Green trace is Vcc, yellow is /Reset. (sorry, the green trace was not set to 10x)
Power-on reset
Brown-out reset
Push-button reset
 Post subject: Re: New Reset circuit.
PostPosted: Fri Jun 02, 2023 3:49 am
Yep, mcp130-450di/to is the part I use for every design. I buy it 100 pcs at a time because I use it so much.
Edit, OK, I didn’t buy 100pcs last time; it was 200pcs.
PostPosted: Fri Jun 02, 2023 6:57 am
Not me! Thanks, that's really useful :D
I've still got a few DS1813s left but at 5 to 10 times* the price of the MCP100 it means I have to really stop and think before using one.
* Here in SA. Variance depending on local stock, the Rand exchange, import / postage and the phase of the moon.
PostPosted: Fri Jun 02, 2023 6:45 pm
MIC708MY looks a good choice too, if you can cope with SOIC-8 surface mount parts (and when I last bought, Mouser had them in stock but none of the MCP parts). At much the same price.
PostPosted: Sat Jun 03, 2023 9:34 pm
Bill (plasmo) got me hooked on the MCP130, very similar to your MCP100. I also add the pull-up resistor like you, but not the pull-down resistor.
I concur that the DS1813 is much more expensive than this alternative. Looks great :)
