It is currently Fri Nov 22, 2024 8:15 am
 Post subject: Junior Computer
PostPosted: Thu Oct 05, 2023 3:21 pm
Hi All,
Lately I've been busy with the restoration of a 'Junior Computer' (Elektor/Elektuur).
I decided to build an emulator for it (still in beta development).
So for those interested you can find it here (open source):
https://github.com/ForNextSoftwareDevel ... orComputer
Best regards,
Dirk.
 Post subject: Re: Junior Computer
PostPosted: Thu Oct 05, 2023 3:48 pm
Welcome! Looks like an excellent idea. You might want to test your emulator's accuracy with the Dormann tests (or others.)
(I'm assuming this is a Windows project? That will certainly have an audience, although there are those who don't use it, including me.)
PostPosted: Thu Oct 05, 2023 4:07 pm
I built one, back in the day...
Sadly I no longer have it - long story involving my usual disregard for "obsolete" hardware back then... Hindsight, etc. ... Ah well.
But like Ed, I don't use windows so can't check it out, but don't let that stop you developing it. (although making it work under WINE might be nice)
PostPosted: Thu Oct 05, 2023 4:33 pm
Good point, WINE usually works - I use it on my macbook relatively often.
PostPosted: Thu Oct 05, 2023 4:51 pm
Thanks for the replies.
Yes, it is a Windows project using c#
Problem with c++ is that it would take much more time to achieve the same functionality.
I did make several programs under linux but that is usually quite time consuming.
PostPosted: Thu Oct 05, 2023 5:48 pm
C# can actually work well in Linux, in a way it provides its own portability layer. However I'm not sure about the UI side (WPF etc) - I've only run console applications this way.
PostPosted: Fri Jan 12, 2024 12:35 pm
Cool project. Have a Junior in real and the successors. But as other slaready mentioned, I could not test the software, as I do not have Windows. With graphic UI MacOS would be preferred for me.
