It is currently Fri Nov 15, 2024 6:54 pm
 Post subject: Earliest 6502 Date Code?
PostPosted: Sun May 12, 2019 4:27 pm
Been looking around on google for this.
Officially the 6502 became available in September 1975. I'm wondering what the earliest date code for one produced by MOS would be? I've seen a 6501 as early as the 34th week of 1975 but most of the white ceramic 6502s I see are 76 or 77. The one on my OSI 300 is the 38th week of 75.
PostPosted: Sun May 12, 2019 4:49 pm
I think you have a very early one there! It would be good if you'd post a photo.
PostPosted: Sun May 12, 2019 5:18 pm
Here's a couple:
https://drive.google.com/file/d/1YgCAIS ... sp=sharing
https://drive.google.com/file/d/1Jun55x ... sp=sharing
PostPosted: Sun May 12, 2019 5:24 pm
Thanks! I do like the wibbly-wobbly hand-routed PCBs from those days!
PostPosted: Fri May 31, 2019 5:07 am
From cpu-world.com forums:
Btw the 6501 was not existent in week 7501;-) It was released in September 75. So oldest possible date codes are around 7533.
6501 date code: 34th week 1975 should around August 18, 1975 to August 24, 1975 (your 6501 is extremely nice one).
6502 date code: 44th week 1975 should around October 27, 1975 to November 2, 1975
The oldest 6502 I saw on internet so far is date coded 3875, 38th week, 1975.
PostPosted: Mon Mar 02, 2020 1:55 am
I have a date code 3675. Bought new and never used. Anyone have any idea what it is worth? I have an older date code in my Apple 1 and I'm considering swapping them out.
PostPosted: Mon Mar 02, 2020 2:28 pm
They're back!
This was made with TopoR.
PostPosted: Mon Mar 02, 2020 2:32 pm
Interesting! I'd imagine even that date code has the ROR bug, and it sounds like your Apple 1 would have it too. I was wondering if any Apple 1s had the ROR bug; was yours homebuilt or purchased from the Byte Shop or Apple?
PostPosted: Mon Mar 02, 2020 2:40 pm
They're back!
Lovely!
PostPosted: Tue Mar 03, 2020 4:05 am
Mine was bought from the Byte Shop. I don't know if it has the ROR bug to be honest. It's #91 on the registry.
PostPosted: Tue Mar 03, 2020 8:50 am
If your Apple 1 works, then you can enter a test program to check whether ROR works. This is perfectly safe; the CPU will produce the wrong result (basically an ASL that doesn't update the C flag) but otherwise will keep running fine. You're probably more familiar with WozMon than I am, for entering the following:
0300: A9 0D 20 EF FF A9 01 18
:6A A2 00 B0 02 A2 03 BD
:1D 03 20 EF FF E8 C9 00
:D0 F5 4C 1F FF 4E 4F 20
:52 4F 52 20 42 55 47 00
This should print "ROR BUG" or "NO ROR BUG", based on whether ROR($01) sets the C flag - it should, but the buggy CPUs won't.
If you do have the ROR bug, I'd be interested to confirm whether my 6502 classification routine correctly identifies even the early 6502 as NMOS - which it should, since it doesn't rely on any ROR behaviour. I'll reproduce it here in hex format, and with an Apple 1 compatible output routine:
A9 00 85 84 85 85 A9 1D
85 83 A9 6B 85 1D A9 4E
47 83 45 83 C9 53 D0 04
80 02 A9 65 20 EF FF A9
0D 20 EF FF 4C 1F FF
This version includes the extra check for a naive 6502 emulator (which implements undocumented opcodes as NOPs). I've slightly modified it to produce an E for that case instead of a lower-case n, because the Apple 1 only supports upper-case.
A real NMOS 6502 should print N; a 65SC02 would print S; a 65C02 with the Rockwell instructions would print C, and a 65816 or 65802 would print 8. If you get anything *other* than N on a ROR-bug 6502, let me know and we'll puzzle it out.
PostPosted: Tue Mar 03, 2020 10:31 am
I was thinking that if I owned a computer that cost as much as a house, I'd be nervous about even turning it on. Then I reveled in the delicious irony that the Apple 1 was one of the computers that was supposed to put an end to the era where a computer cost as much as a house. :-)
PostPosted: Tue Mar 03, 2020 11:50 am
That is indeed a (golden?) delicious irony.
I tried the two above programs in the Pom1 emulator, which evidently includes a naive 6502 simulation - NO ROR BUG and E were produced, respectively. I doubt anyone has taken the time to produce a 100% accurate emulator in this respect.
PostPosted: Tue Mar 03, 2020 12:05 pm
FWIW, my go-to emulator for quick-and-dirty tests is the on-line Apple 1js page; it also produces NO ROR BUG and E. I'll run it on my replica SBC when I finish up the current soldering mess on my workbench, but I have little doubt it will produce `NO ROR BUG` and `n`; it's a Rockwell NMOS 6502 with a very dodgy emulation of the video output to a serial port run on an Arduino Nano.
PostPosted: Tue Mar 03, 2020 4:40 pm
Not to be a curmudgeon, but why are there two topics going on elderly 6502s?
