It is currently Sun Nov 24, 2024 3:44 am
 Post subject: sunplus 8502
PostPosted: Thu Jul 19, 2012 8:46 pm
Hi there,
anyone knows more details about the sunplus 8502, a 6502 derivative that is supposedly used in the HP35S calculators?
http://www.eetimes.com/design/embedded/ ... geNumber=1
Thanks
André
 Post subject: Re: sunplus 8502
PostPosted: Thu Jul 19, 2012 10:17 pm
fachat wrote:
Hi there,
Thanks
André
Hmm...the MPU in the Commodore 128 was an 8502. Maybe this microcontroller contains an 8502 with a mask ROM attached in some way. :?
PostPosted: Fri Jul 20, 2012 7:59 am
Sunplus split into four companies. Generalplus is the company the now makes the ICs. I suspect HP is using a GPL085A but I can't find a datasheet.
http://www.generalplus.com/product.php?prot_no=1&func=sh
Scroll down to the 'Low Voltage LCD Controller' section
Andrew Jacobs
PostPosted: Fri Jul 20, 2012 9:43 am
(Parenthetically: Sunplus 8502 is not the same chip as the CSG 8502. Much like the CSG 6501 is not the same as the MOS 6501... there don't seem to be enough four digit numbers!)
A previous post linked to this discussion where we read that the Sunplus 8502 is a core, not a chip, and the chip we seek is a SPLB31A.
PostPosted: Fri Jul 20, 2012 10:20 am
In which case its datasheet is here
http://www.datasheetarchive.com/indexer.php?file=DSA00130543.pdf&dir=Datasheet-08&keywords=SPLB31A&database=user-highscore#
Andrew Jacobs
PostPosted: Fri Aug 24, 2012 6:46 am
BTW I found more details on the sunplus 8bit processor core: http://www.sunplusit.com/english/produc ... tures.aspx
PostPosted: Fri Aug 24, 2012 7:49 am
Great! There's a datasheet for a related chip here: http://mcu.sunplusmcu.com/soft/1502A_Data_sheet.pdf which details the CPU programmer's model: very much a 6502.
Found by searching for ["182 instructions" sunplus]
PostPosted: Wed Dec 07, 2016 9:06 am
fachat wrote:
Hi there,
Thanks
André
As the link has rotted, here's the Internet Archive to the rescue:
http://web.archive.org/web/201012091304 ... geNumber=0
http://web.archive.org/web/201012091304 ... geNumber=1
http://web.archive.org/web/201012091304 ... geNumber=2
Just two key components
On one hand, I was disappointed to see what was actually inside the calculator. That's because it's not a very interesting design. It's just two key components--an 8502 microcontroller and a flash memory chip. Both of those parts are covered by a blob of epoxy, as you can see in Figure 2. The processor is under the bigger blob.
The 8502 is designed by Sunplus Technology, a Taiwanese company. It's based on the 6502, an 8-bit processor that first appeared on the Commodore 64, which was popular around the same time that I purchased my 15c. The flash memory is a generic part, and no specific vendor is used. It's generally based on whatever is available at the right price at the right time.
The 8502 that's used here also contains the system's power management and all the typical chip-set functions. This includes an LCD diver, a keyboard controller, and so on.
PostPosted: Wed Dec 07, 2016 9:20 am
BitWise wrote:
Link rot has occurred, but there's now a datasheet for the SunPlus SPLB31A here:
http://www.ic72.com/pdf_file/-/428519.pdf
SPLB31A
2368 Dots Data Bank
Preliminary
JUL. 24, 2001
Version 0.3
Unfortunately the CPU description is minimal - we don't even get an instruction count, let alone a programmer's model.
Edit: the same datasheet appears presently as the renamed GPLB31A:
http://www.generalplus.com/doc/ds/GPLB31AV14_ds.pdf
PostPosted: Wed Dec 07, 2016 2:45 pm
But at least we now know that the 6502 first appeared in the Commodore 64...... !
PostPosted: Wed Dec 07, 2016 5:08 pm
I suppose that's a good indication of the depth of research going into the article!
Users browsing this forum: No registered users and 74 guests
cron
