Hi Dajgoro,
Dajgoro wrote:
My idea is to try to use just a single ATX power supply.
I wouldn’t recommend making extensive alterations to the C64 main board just to get rid of the 9V~.
Keep in mind that the CPU 6510, VIC-II 6569, SID 6581, the two CIA’s 6526 and the PLA aren’t produced anymore. So why take any risk.
Dajgoro wrote:
Now the question is where am I going to find a 9V transformer...
If I recall right, you can’t / won’t buy on eBay? However, if you’re searching for a replacement, a 1A (10VA) will suffice, especially if you don’t use a cassette tape drive you could get a 500mA (5VA) one.
The 9V~ of the C64 power brick can be reused, it comes directly from the transformer, which almost never dies. You only have to take care of 5V=, at least 1.7A.
/off topic
MichaelM wrote:
...and found an interesting collection of projects.
Yes, there are a lot of projects / peripherals for the Commodore 64. Anything in particular? My favorites are:
SD2IEC
http://www.c64-wiki.com/index.php/SD2IECBased on an ATMega644 and an SD-Card, it simulates a Commodore 1541 diskdrive. It’s open source and easy to build. It could also be used for homebrew 6502 systems.
EasyFlash(3)
http://skoe.de/easyflash/doku.phpA modern Cartridge providing 1MB of flash memory. Also open source. Version 1 is DIL 2.4mm pitch and version 3 is TQFP100 0.5mm pitch.
S-Video hack
This is a less common hack to provide a very good S-Video signal, it involves removing the HF-Modulator and provides a new circuit for delivering chroma and luma separately from the VIC-II to the CRT monitor.
